The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
Magluvin
Hey Jim  here is an idea
Try Ossies circuit using 2 caps instead of the battery.
In his circuit, the drive battery gets its charge from the second battery through the resistors as a trickle charge.
If you have 2 caps, it would be worth the go.
Mags
Jimboot
Voltage rising but I've seen it do this b4 , peak , then drop. I love this wave tho. 1 D cell started at 1.322 gone as high as 1.327 amps constant below zero. 920RPM
Jimboot
Quote from: Magluvin on March 26, 2010, 06:37:53 AM
Mags
I was thinking of something like that. I buggered up my 1st attempt at it. As voltage dropped on both batts. I think I had something arse about. I'll get another super cap tmrw
Jimboot
This is the most efficient I have seen this motor run. Voltage now at 1.329 RPM constant amps still below zero on the meter. Would that mean it's running in the microamp range?
Jimboot
Voltage up to 1.330 amps looked to have dropped rpms @ 980. Wave looks even better. I haven't touched it since it started the run.
