The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
Jimboot
Can someone look at these calculations pls. At just under zero on the 1A meter I'm assuming it's running at .0008A X 1.30 =0.00104w? 980rpms
1.331 is blinking :)
Jimboot
steady at 1.331 970rpm
Magluvin
I would just let it run. Till it reaches some significant lower voltage. But if steady or goes higher, let it run. =]
Mags
gyulasun
Quote from: Jimboot on March 26, 2010, 08:59:39 AM
Hi Jim,
But you have already calculated it, assuming your estimation of the .8mA current is correct.  And if you consider the 1.331V battery voltage then the input power is 1.064mW.
If you could produce 2x 3x as many output power by the pu coils, you would be in a happy position... ;)
Gyula
Jimboot
I feel like I'm hogging the thread. 1.332 v 930rpm
