The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
Jimboot
Quote from: FatChance!!! on November 23, 2010, 03:22:38 AM
Your videos does not show 1600RPM, its more like 160 RPM.
Just look at the wobbling shaft rod.
If it really was 1600 RPM then the wobbling would not be visible.
Yes there is a wobble but the frame rate of the iPhone makes it look very different. I show you on the vid the rpms. If you don't believe me I couldn't give a toss.
Jimboot
Had the osier motor up 9000rpm. I don't think the reeds will switch much faster. The Rodin coil is amazing. To use so little copper and achieve such high speeds compared to what I had been doing.
Low-Q
Quote from: Jimboot on July 11, 2010, 03:59:31 AM
Thanks Gyula.
Here is the scope shot. The 1st trace represents what I was measuring in the last vid.
Looks like you have about 90 degrees phase shift between green and yellow measurements. Is this due to some filter function/delay somewhere in the circuit?
Vidar
Jimboot
@low-q that was just me using a hdd coil as a pick up. It is purely what is coming off the coil.
Magluvin
JIMMY!   Last I seen of you I believe you were saying the motor was causing headaches.     What made you swing to the new Christmas coil?  =]
Mags
