Steorn's Patented Measuring Device & SKDB
Started by gravityblock, February 12, 2010, 01:22:05 AM
gravityblock
A Torque Sensor is mentioned in the SKDB material for tools needed for testing.  This is used in the Patent Measuring Device.
A torque sensor is a device for measuring and recording the torque on a rotating system, http://en.wikipedia.org/wiki/Torque_sensor
GB
gravityblock
A Displacement Sensor is mentioned in the SKDB material for tools needed for testing.  This may be used in the Patent Measuring Device or in the assembly of the Orbo.
Capacitive displacement sensors “are non-contact devices capable of high-resolution measurement of the position and/or change of position of any conductive target”.  They are also able to measure the thickness or density of non-conductive materials.  Capacitive displacement sensors are used in a wide variety of applications including semiconductor processing, assembly of precision equipment such as disk drives, precision thickness measurements, machine tool metrology and assembly line testing. These types of sensors can be found in machining and manufacturing facilities around the world, http://en.wikipedia.org/wiki/Capacitive_displacement_sensor
GB
lostcauses10x
Seems folks forget that even in magnets and materials related such as core materials have CEMF.
Any moving magnetic field that crosses a conductor causes a CEMF. Be it a magnet, or a core or even a nail.
Simple answer to 90% of Sterons BS.
The other aspect is change is never instant. That is the other 1% of Sterons crap.
You folks should be asking for real input, to output, noting else. Seems you will never get it from Steorn.
As for there education modules they are tailored to their claims.
lostcauses10x
gravityblock
The crap patent on the measuring device is such that such equipment is built to need.
There is noting new in that device. Even the way it is done is not new.
If you need a torque measurement, you  build to the situation.
If you compared the input cost to the variations, it still will not be ou.
They play a game of look at this, and never, never, real input to out put.
If they had ou they would have shown it with out the BS. They have not.
they say it exists and then give out BS scope shots to say it might.
hell the output coil on the last demo does not even show up in the thermal imaging. Them input coils are easily seen. No OU.
gravityblock
Quote from: lostcauses10x on February 12, 2010, 12:58:06 PM
gravityblock
I could care less if it is new.  If it is new or old, then it may be needed for a successful replication.  The patented measuring device is to test and match the materials in order to have the maximum performance and best chance of OU.  Even the same type of core materials and magnets will have slight variations within their specs and the tests will help you to match the materials for the build.
If you think Steorn is B.S and not showing OU, then you have no reason to be here other than to distract from the topic that is being discussed.   I will not tolerate it.  You've stated your opinion about the Patent, the measurements, the SKDB, and the Orbo......so you should have nothing more to say.
GB
