Graphite-Paper - Aluminium-Foil galvanic cell with 1.7 to 1.92 Volts
Started by hartiberlin, February 17, 2010, 01:39:32 AM
Rapadura
Maybe a small set of this alufoil cells may power up a beautiful array of super bright white LED's that can illuminate a room... If the alufoil lasts for some days, it could be worth replace the light bulb of the room by the array of LED's.
hartiberlin
Sorry for all the delays, but I am heavily in website programming work
caught up..
but now here are some of the new videos.
http://www.youtube.com/user/overunitydotcom
The rest still needs to be cutted and encoded.
Please subscribe, rate and post a few comments on the Youtube
comments also.
Many thanks.
Regards, Stefan.
Harvey
Stephen, I am curious regarding the waste product and the specific chemical reaction involved. Is there any links to the chemical process and the proper handling of the waste products? Many thanks for your research on this!
Cheers!
8)
ResinRat2
Stefan,
I like the overunity.com logo you had on your videos.
Thanks for posting your work on this.
RR2
hartiberlin
Hi ResinRat,
yes, this will be my new logo for the site.
I still need to draw it up much clearer and integrate it into
the new design I will soon have.
Well, regarding the waste products,
there will be mainly Aluminiumhydroxid produced, which just could
be flushed in the toilet
and I still have to make a few experiments regarding the KMnO4.
Also I will have to see, if I can make this a reversible experiment,
where the ALufoil can be recycled, but as it is so cheap and you can get it inside
every supermarket, this can be "recharged" pretty fast, by just using new
alufoil.
Also I see this mainly more relevant for selfmade emergency batteries,
which you can make at home, when there is a power outage.
So you need only some "drano" sink cleaner ( has got the NaOH in it)
something like this:
http://www.drano.com/clogged-kitchen-drain/default.aspx
(or some other cheaper brand that just only has NaOH in it)
some alufoil and some selfmade Graphite electrodes with stainless steel
mesh inside and some water.
Hope this helps.
Regards, Stefan.
