Unified Gravity and Magnetic Generator Principle
Started by onthecuttingedge2005, February 17, 2010, 06:53:35 PM
mscoffman
If anyone does a build. I recommend separating the two
parts of this: One) would use some external electricity to
remove the top ball from the magnetic field...Two) would
be to see how much electricity you can generate based in
the ball's motion. Step Three) would be to bring these two
value together. Conservation of energy says you should be
able to get close to bringing them together.
:S:MarkSCoffman
to avoid moving parts except for the magnetic ball, I would like to go with something like this. some of you more advanced electronic experts might have a solution to the circuitry needed to make this work.
Rapadura
Jerry, your idea is very good.
I only fear that the amount of energy that will be needed to discharge into the top coil will have to be very large in order to separate a neodymium ball (or it will be a steel ball?) from a neodymium magnet.
Maybe if the ball was a steel ball, and had a coil inside... When it reaches the top the coil could be activated, turning the ball into an electromagnet, and if the ball was not immediately expelled because it is not with the same pole face to face with the neodymium magnet, but the opposite pole, then the polarity could quickly be reversed (just a quick first pulse to turn the ball into a electromagnet, and, if it is not properly aligned to cause repulsion, a quick second pulse with the inverse polarity).
I'm not sure, but I think if a strong Neo magnet is with the same pole face to face with a not so strong electromagnet, we can have nice repulsion forces...
here is another idea that probably won't work but I thought I'd pass it along.
jfej004
Has anyone built a serious magnetic generator? I've read up on so many scams...Thanks!
