Magnetic amplification and neutralization motor by Art Porter
Started by LarryC, February 20, 2010, 05:07:38 PM
alextecmen
Quote from: synchro1 on October 16, 2020, 12:13:13 PM
The amplitude of the AC input needs tp power the coil to an equal gauss of the magnet. The frequency of current reversal, timed to coincide with the Lenz reversal of the coil.
The coil inductance measured with the magnet inside the coil core will yield the correct SRF with the standard equation:
OK, thank you, I found this information from
it is from another coil a little less long
will serve as orientation
What does the experimenter expect from this coil arrangement ?
Does he/she knows Keith Kenyons em-concept ?
The Angus-Motor ?
The Flynn Bros. magnetic coil arrangement, force amplifying/neutralizing ?!
Thomas Townsend Brown GB application his up to 1 Mio. times force out/eWatt in capacitive winding drive ?
Sanshiro Ogino s * basic factor * and effect ?
For higher mmf output = higher frequencies  = higher RPM
Tesla Inc. cars with nominal 18000 (eight-ten thousands) RPM e-drives equipped
Based by T.T.Brown,Plauson,Imris : 2500 W continous force out/25 eWatt in possible ( as prototype realized )
It does not change much !
Sincerely
alextecmen
Here we have other data of the constructor
you look at your measurements, they seem pretty good to me.
But you have to experiment if this type of coil can really provide very good energy gain results.
Here are two questions, I can believe and I cannot believe
The tests and data that any source provide us must be validated, the safest way is to carry out the prototypes and test their operation.
Nothing costs to verify experimentally, if so desired, or required, everything according to our scope and possibilities
synchro1
Art Porter's coil is designed to have an SRF of 60 cycles per second so he can run his 1500 watt lamp directly from the coil with no full wave bridge rectifier.
alextecmen
The control used by Art Porter is very expensive, it has a very high price.
There is one that knows a cheaper one and that can fulfill the same function of activating the relays.
Or if there is a scheme to build a simple control to activate the two relays. and at what frequency you have to operate them.
Thank you all for your comments and contributions
