Russian magnet motor
Started by joe, March 21, 2006, 09:26:11 PM
stiffy
Quote from: gn0stik on June 07, 2006, 03:01:39 PM
There is no such thing as a shielding material that is NOT ferromagnetic.
It's been a long time since I actually looked at this stuff. Anyway, the screening material should be some diamagnetic material (plastics, lead, gold, etc. )
stiffy
Quote from: jake on June 07, 2006, 10:21:54 AM
Quote...we have a classic combustion engine.
Worth noting that typical internal combustion engines are 30% efficient (mostly heat loss, but the mechanical losses are pretty stiff too).
True, but we are able to cruise a 160 km/hr on the Autobahn despite the bad efficiency of the combustion engine. This Russiam setup remains interesting nevertheless.
FreeEnergy
from: http://www.overunity.com/index.php/topic,1073.0.html
Quote from: gyulasun on May 30, 2006, 08:39:51 AM
You would need diamagnetic material like bismuth or pyrolytic graphite sheets which are highly diamagnetic.
Found a link on bismuth: http://home.earthlink.net/~lenyr/levmag.htm and it seems to be formed easily at home to a flat sheet format too due to its low melting temperature point.
Also a good info on diamagnetic materials is here:
http://www.physics.ucla.edu/marty/diamag/ajp601.pdf        and also here:
http://www.physics.ucla.edu/marty/diamag/diajap00.pdf
The "latest" strongly diamagnetic material is pyrolytic graphite and it is available just in the correct shape for your arm:
http://sci-toys.com/scitoys/scitoys/magnets/pyrolytic_graphite.html
Now your idea can be tested! Go ahead!
rgds
Gyula
Anatoliy
Hello!
Meanwhile I hide some secrets of a design of the engine. Due to them, the engine will work with the ferromagnetic screen.
Yours faithfully, Anatoly.
stiffy
Quote from: Anatoliy on June 08, 2006, 04:09:55 AM
Hello!
What about a shutter mechanism such as this for the up stroke screening?
