IST'S 7 FREQ JT HUMAN TUNER BOARD !
Started by innovation_station, February 21, 2010, 02:57:19 PM
innovation_station
Quote from: sirmikey1 on February 22, 2010, 12:10:14 PM
Are you at all familiar with Tesla's copper plate cancer/tumor device? I just can't picture him as a con man.  What frequency was he using; and how was this applied?  Air core JT with 555?
  See if you can get a sidac to start a ceiling fan on a AA battery. I don't understand the rotoverter run caps.  Do they kick-in under load?
Mikey
sure they do ..  i had a cfl back fire .. and cause my coil to throw plasma ...
i have a video ..  also if it wont lite the first time FLICK THE SWITCH!
same old ...
innovation_station
nope im not formilliar with it ...
sounds like i could whip it up in a few min if you have plans ..
i have all  i need laying round ...  including 3 tuned copper plates 7.75 "   with 3/4 hole in the center ...
sounds like alum pipe and a crystal ...
please share any info you may have ..
i will build it  next ..
ist!
sirmikey1
ist,
  CFL backfired?  Did you repeat it, to test results?
  Jeanna mentioned Tesla's cancer cure thing, I think it was in the Stubblefield thread.  Two copper plates, one front and one behind, and then I'm guessing that he used some certain frequency.  I'll dig around to see what I might find on it.
   See if you can come up with a beefy 1.5v JT circuit.  Just how much power is there with the spikes?   Probably best to test 1.5v for the Earth Batteries, and then jump to 12v.
Check this out...
http://www.youtube.com/watch?v=6tfWsKgqHc0
Mikey
innovation_station
the wonder coil is what you need!
i used hook up wire and a goldmine 1"  and a radio shack spool ..  1.5v 3055  5 turns
ist
ill find it and make a better video soon !
sirmikey1
  Do you think you can surpass what those two are doing with heat and filament bulbs, and motors; beefy JTs?   The rotoverters are powering 500v motors with one leg, 110 volts, using start caps to kick off and then run caps to keep in strong under load.  They claim to be running huge motor/generators on milliamps.  Here is a paste from the Rotoverter Forums:
Look at this drawing of the RV circuit - see how the AC power feed from grid line or inverter) hooks to lines 1 and 2 and line 3 is "blank" http://images.google.com/images?hl=en&q=rotoverter%20circuit  The run cap and start cap go across lines 2 and 3...the run and start caps are in paralell - to start up, connect the start cap... once the motor is up to speed disconnect the start cap and have only the run cap connected between lines 2 and 3.  Adjust the run cap UF value by inserting differnet  size run caps until you get draw down as low as possible at idle. I get a 3450rpm motor to run on .18A ac at 120V input and I use a 9uf run cap for this. Change the uf valeu of your run cap when you turn a load on the shaft too - "tune it" for the particular shaft load... change those uf values in 1uf ioncrements - so its good to have a few 1uf AC caps
to experiment with.. ciaoK
http://panacea-bocaf.org/rotoverter.htm
End Paste,
Mikey
