Thanks to ALL for your help!!
What is the best way to extract electricity from a pendulum?
Started by Rapadura, February 21, 2010, 10:34:57 PM
Rapadura
I think I should reformulate:
What is the very best way to extract electricity from this pendulum, with maximum output wattage AND minimum friction (including "magnetic friction" due to Lenz's Law), in order to make it swing for as long as possible?
mr_bojangles
well, if you use a magnet as a counterweight (being as direct as possible), and allow its swing to pass an inductor coil, this would generate electricity
now, the pendulum has the most momentum at the bottom of its swing, so with previously said method, logically the coil would be placed at the bottom of the arc
the more mass a pendulum has, the more efficient, as well as the length of the "string"
the stronger the magnet is, the more drag it will encounter
similarly, the closer the magnet swings to the coil, the more drag you will induce
neither of which will induce nearly the amount of energy it takes to keep the pendulum going
also, the faster it travels the more drag you will encounter
that is the most direct way i can think of, indirectly i would look at the milkovic 12x machine
while i am partially doubtful it actually does increase output, its the best example of how to have a pendulum generate electricity without any induced drag directly into the pendulum itself
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
TechStuf
QuoteWhat is the very best way to extract electricity from this pendulum...
That would depend on what you mean by "THIS" pendulum.  It's all relative.
From what is given in your description, the least amount of friction may be provided by a fulcrum allowed just enough vertical movement to impinge upon a bending piezo....
And of course, aerodynamic pendulum and swing arm shapes....I would also recommend a dry bearing hub assembly, as is found on the older style roller skates.
Blessings in Christ Yeshua,
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
onthecuttingedge2005
remember that gravity is only a return of expended energy, nothing more.
Judges
I am Quoteing Mr.Bojangles above,,,,Pendulum sounds good,,,maybe with some left over?
He has said it much better than I,,
What I would add would be,dont stop work
on it and don't stop posting,your results.
Sounds Durn Good to me.
Good Luck and Play SAFE
Joe in Texas
