Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
ltseung888
How to revive the American Dream
At one time, the American Dream was founded on the strength its scientific progress.
USA modernized its farming industry.  Now less than 1% of farmers can support the hungry mouths of the entire nation.
At one time, the manufacturing strength was second to none.  Cars, Planes, Electrical Appliances dominated the World Market.  The highways and airports are the envy of the World.
Even now, the Computer Industry and Internet is dominated by American ingenuity.  Yahoo, Youtube, Google and Facebook created many young millionaires.
Can America dominate once again in the lead-out or bring-in energy field???
Has America lost its edge in scientific progress???
Has America degraded to naysayers and insulters???
FatBird
Lawrence,  Thank you for sharing that conversation with your friend.
That is very interesting to read because it is a real life situation that probably thousands of familes have been through in this bad economy.
Thanks again & have a great week.
poynt99
Quote from: The Observer on December 06, 2010, 12:13:00 PM
Poynt,
You said,
---> The question is to see if sound is being amplified...<--- not to make a self running device.
However, I think your idea is a good start to a level 3 or level 4 experiment having to do with this phenomena.
It is important to realize that the tube uses only a SMALL PORTION of the wave energy emanating from the speaker.
This small portion of wave energy is what gets amplified.
One logical way of seeing if a wave is amplified comes to mind.
        How bout comparing input wave vs. output wave ?
        E2Matrix suggested a purchasing a Decibel Meter... good idea !
Best Regards,
                     The Observer
Let me try and save everyone some time.
You will encounter a perceived increase in sound level with your experiment. You may also see an increase on the SPL meter. So the sound at this frequency will indeed appear to be amplified. I think this was a forgone conclusion by most, but anyhow, what do you conclude from this Observer? Here is a hint ;): When you blow over an empty coke bottle, and are able to "find" the right frequency and make the bottle resonate with a loud tone, you started out with only a very quiet sound of air passing over the hole. Was the sound amplified?
Acoustic vs. Electric Guitars
Your acoustic guitar is louder than your electric, because the acoustic is far more efficient at converting the mechanical vibration of the strings, to sound pressure waves in the air. There is nothing mysterious about that I trust?
With the same energy imparted to the strings in both cases, the acoustic will sound louder because it converts more of it's input energy to sound pressure waves. This is mainly due to the flexible nature of the sound board, the presence of the resonant cavity, and the Helmholtz Resonator nature of the sound hole. On the other hand, the strings on the electric will vibrate for much longer than those on the acoustic, because more of the energy remains in the strings which sustains the standing wave that was set up in them. Tested properly, this will hold true. It's important to note that the pickups on the electric must be removed for this test to be valid, because the magnetic pull in them heavily damps the string vibration. An amplified piezoelectric microphone could be placed on the electric's body to aid in this test.
On Conversion and Efficiency
The creation of sound is all about converting some source of input energy to sound pressure waves. A classic example is that of an electrical input being converted to the mechanical movement of a loudspeaker. The loudspeaker diaphragm converts this mechanical oscillating movement to longitudinal sound pressure waves in the air.
The acoustic guitar, albeit not thought of as such, is also an energy converter. The energy of a mechanically-plucked string and its ensuing vibration, is also partially converted to sound pressure waves in the air.
Neither "converter" is 100% efficient at doing its job. Often, efficiency diminishes sound "quality" or bandwidth. Resonators are very efficient converters, especially if they are made with high "quality" (Q) factors. However, they sacrifice bandwidth for efficiency. It would seem you can not have the best of both worlds. Resonators are very good at working with single or narrow band frequencies. Such is the case with loudspeaker bass reflex (tuned port) systems. (Note: I recommend you study bass reflex design and how Helmholtz resonators are used to amplify OR absorb acoustic energy at specific frequencies, if you are not already familiar with it. It is quite relevant to this discussion and your notion that these resonant "systems" are free energy.)
Tuning Forks
A tuning fork is a type of resonator. It works well at a single frequency. By the very nature of its construction however, it is a poor energy converter in terms of converting mechanical vibration to sound pressure waves. It is analogous to the electric guitar example. Hint: If you can not hear a tuning fork very well, place the "tail" on a wood surface, or even on your skull, they both make fairly good transducers.  :P
Two identical tuning forks in sympathetic vibration make each other more efficient at converting their combined mechanical vibrations to sound. A single tuning fork alone creates very little by way of sound pressure waves, and some of the fork's energy is dissipated in internal torsional losses and frictional heat from the air resistance. With a pair of forks placed in the proper mutual plane, they can convert some of that lost frictional energy to sound pressure waves, increasing the overall sound pressure level.
When the first tuning fork is struck, its tines vibrate and create an undulating pressure zone between it and the adjacent tuning fork. These pressure waves are what imparts energy to the second set of tines, and results in 4 tines vibrating vs. two. Sound intensity is increased. Now, imagine this pressure zone between the two inside tines of each fork. The tines co-vibrate due to mutual excitation, but in doing so, they offer more "impedance" to movement (due to the pressure zone) compared to if they were freely oscillating alone. This causes the 4 tines to vibrate for less time than two would in isolation.
As with the acoustic guitar, the result is a louder sound, but for less time. The total energy output is equal to the energy input. The output energy can take several forms, depending on the construction of the "converting" device. Overall, no total energy is gained in the system, even though a perceived amplification may have occurred.
The Test
Why not cut to the chase and create a self-running device?
Actually, I rarely do this, but my proposed test was intentionally flawed. It was a test of your knowledge in a way. I didn't see the correct response however. :(  Do you know why the test is flawed? Hint: read the above.  ::)
.99
minde4000
Quote from: ltseung888 on December 06, 2010, 07:27:21 PM
You poor sick man... do you read what you post?...
Pirate88179
Quote from: poynt99 on December 06, 2010, 09:55:32 PM
You will encounter a perceived increase in sound level with your experiment. You may also see an increase on the SPL meter. So the sound at this frequency will indeed appear to be amplified. I think this was a forgone conclusion by most, but anyhow, what do you conclude from this Observer? Here is a hint ;) : When you blow over an empty coke bottle, and are able to "find" the right frequency and make the bottle resonate with a loud tone, you started out with only a very quiet sound of air passing over the hole. Was the sound amplified?
Tuning Forks
The Test
.99
Darren:
Once again, this is possibly the most clear and concise explanation of these devices that I have ever seen.  It all fits with what I thought I already "knew" but now I know why I know it.  (If that makes any sense)  Thank you.
And to the others, when someone explains known physics that has been proven through countless experiments and research, they are not a naysayer but an educator.  This type of information can save many folks a lot of time and effort from rediscovering the wheel, as my late Father used to say.  Is there something yet undiscovered about tuning forks and guitars?  Possibly...even maybe but, so far, I have not seen that postulated yet.
And please, I do not intend this in any way to be demeaning to anyone here.  It does not mean to quit searching for something new, not at all.
