Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 168 Guests are viewing this topic.
Paul-R
Quote from: Bruce_TPU on March 24, 2010, 11:22:59 PM
Dr. Mark Snoswell is very reputable and has a very keen mind.  He is correct about Magnacoaster...
...but what did he say about Stan Meyer?
Bruce_TPU
Quote from: Paul-R on March 26, 2010, 01:17:08 PM
I have never spoken to Dr. Mark Snoswell about Stan Meyer.  I do know one thing... Stan Meyer was never "poisoned" and that is a terrible internet, urban legend, that distresses his family everytime they hear it.  That much I do know.
ltseung888
More on Magnacoaster
Sterling Allan rated them as Number 7 in his top 10 list.
Magnacoaster Motor Company, Inc. of Canada claims to have an over-unity generator they call "Vorktex" that produces electric power without using fuel.
The crux of the design is a solid state system that involves some very high-powered permanent magnets and some specially-wound coils, along with some proprietary circuitry. The coils are immersed in a dielectric oil that is pumped through the system to prevent arcing between the coils from the high voltages and frequencies that otherwise create plasmas that destroy the coils. A lead acid battery bank serves both as the input and the output. The unit has to be shielded or it broadcasts EMF.
I believe that they still need to perfect the technique of adjusting the Power to external load.  The energy generated might be too much and required continuous pumping of dielectric oil.  I believe Sterling Allan checked them out and interviewed them.  In the interview, they mentioned that their device would increase in frequency, voltage and current.  It was similar to echoing and drawing energy from the surrounding.  I would use the term â€" lead-out or draw-in electron motion energy from the surrounding.  I would not dismiss them as hoax at this point as I shall have one of their units to work with in the coming weeks.
It will be fun to compete with them with one of the FLEET products.
ltseung888
Progress on Fleet at the Hong Kong Invention Association
Tseung: “Thank you for coming on a Saturday.  Many of you have jobs on weekdays.  This is an entirely voluntary project and I appreciate your involvement.  I do not mind if you only work on weekends, loan your equipment on short periods, contribute only a few dollars or just come and cheer.  I already claimed success on the theoretical front.”
Cheng: “My space is over 8,000 square feet rented from the Hong Kong Government for non-profit uses.  It is not decorated.  I intend to host a free exhibition for the inventions from the Hong Kong Invention Association in the coming weeks.  There may be space for permanent exhibits if needed.”
Chan: “My factory owner friends in China are willing to help in whatever way they can.  They will supply toroidal transformers of different sizes initially.  They will participate in the product design and production when ready.”
Yung: “I do not mind sourcing the various components and doing the experiments with guidance.  I have much to learn.”
Tseung: “Remember that we shall publish the results in the name of the Hong Kong Invention Association to benefit the World.  Some of you will find commercial value and may want to keep certain results confidential until you have products to sell.  I respect that.  So please tell me only the results that you are willing to share with the World.”
Yung: “Will there be dangers involved?  I can see obvious military applications with FLEET.”
Tseung: “Lee Cheung Kin is working with the Chinese Military.  He will pass our findings.  However, it will be a one-way street.  If he accidentally leaked confidential information from the other side, both he and us will be in trouble.  So please be careful.  Do not try to extract information from him!”
Chan: “This FLEET project is like the pulled pendulum.  There is no secret once you explained it.  Now you are saying that electron motion energy can be led-out via pulsing at the resonance frequency of many LCR resonance circuits.  The statement is reasonable and self evident.  It points to the right direction of research.  I see no danger.”
Yung: “Was Stan Meyer poisoned?  Did his device work?”
Cheng: “I am also working with another group in China on a fuelless car.  The research results are promising.  It is a hot topic at present.  There is much information on the Internet.”
Tseung: “When you have your own research results on DC Pulsing to a resonance circuit, you will know for sure.  You will get help from a number of HKIA members.  Some of them are skeptics.  If you are scared and find the project dangerous, withdraw.  I do not mind the danger myself because my life is practically over.”
Chan laughed: “I can see your point.  It is better to die gloriously doing something worthwhile to benefit the World than to walk to your grave  in comfort.  I feel the same way.  My children have grown up.  It is time for me to enjoy my life as I see fit.  There is always danger in life.  Even crossing a busy street in Hong Kong has its dangers.”
Yung: “I just want to know the answer.  It is killing me â€" the theory is far too simple.  A pulled pendulum can lead-out gravitational energy.  A DC pulsed resonance circuit can lead out electron motion energy.   Count me in.  In the worst case, there will be one more dead body.”
ltseung888
Conversation with a Skeptic Inventor
Skeptic: “Do you think a couple of poor inventors in Hong Kong could compete against institutions such as MIT.  In your post, you stated that they already received US$4 million working on similar projects?”
Tseung: “I believe that you said that the Tong Wheel would never work at one time.”
Skeptic: “That was a totally different story.  Your Tong Wheel can only generate 2-3 watts.  It has no practical value.”
Tseung: “You played with it.  You measured the Input and the Output power yourself.”
Skeptic: “The meters may not be correct with their RMS values.  The oscilloscope waveforms are more convincing but I am no expert in reading them.  You could be fooling me.  It is like a doctor showing me an X-ray of my chest.  I just had to trust him.  But we shall not discuss history.  Let us focus on FLEET.”
Tseung: “In the theoretical understanding, you can imagine that the transformer core is made up of many tinny magnets vibrating or oscillating together.  If we can use the right push or pulse on a pendulum to lead out gravitational energy, we should be able to pulse these tiny magnets to lead-out electron motion energy.”
Skeptic: “Is that the reason for using DC Pulses?”
Tseung: “DC Pulses have been shown to work on the Stan Meyer and Bob Boyce prototypes?  We do not need to flip the tiny magnets around.”
Skeptic: “You cannot believe anything on the Internet.  As you stated, there were debunkers, agents from Big Oil and stupid non-scientists.”
Tseung: “That is why I use the Hong Kong Invention Association Members to do a totally independent FLEET experiment.  It is entirely voluntary.  Some people may find it fun and educational.”
Skeptic: “It took you five years to get the Tong Wheel prototype working.  Would it take you another ten years to get FLEET working?  We do not have the patience and you may not have that many years to wait?”
Tseung: “In the field of innovative inventions, it is impossible to estimate the experimental time.  It could be a week, a month or ten years.  That is the fun and the torture of inventing.”
Skeptic: “I shall come again after your FLEET experiments are successful.  Meanwhile I shall not waste my time.  You can torture others but not me!”
