Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 114 Guests are viewing this topic.
Charlieb000
Quote from: tagor on December 27, 2010, 08:14:19 AM
I dont understand , where is the video 6 ?
i was assuming you would google it
http://www.youtube.com/watch?v=gC6Qlj1Mbo8
hopefully my response is not too confusing, if it is then dont worry about it, this topic isnt about the 2SO:
as for "force is not energy", people think its gravity that makes it work - gravity is a force and accumulated it has energy. but i dont think its gravity.  i think its the force that the link refers to. this "psuedoforce" occurs naturally due to the pendulum constantly accelerating on the pivot point. they call it psuedo (false) due to the other force (meantioned there) which is a true force (that is equal and opposite to the psuedo) which is observed. but there is no observed work done by this psuedo force therefore its false to them. the 2SO makes this force do work and you can use formulas to find the useful work (energy) output. the pendulum keeps on moving due to the conservation of energy (if you want to make it more efficient, make it saucer shaped to make it aerodyamic) and its swing is not effected  by the load - or a little bit i guess depending on low loading (I/O on FE devices are never completely isolated). it is also due to the conservation of energy that these two equal and opposite forces occur in order to rotate the mass around a pivot.
what is being done is that the output is leached energy from the de-aceleration of the pendulum in one direction and while the momentum is removed the pendulum accelarates in the new direction.
i cant really explain it plainer than that.
Charlie.
Charlieb000
Quote from: The Observer on December 27, 2010, 01:22:02 PM
           The Embedded Magnets are Extremely Powerful, Atomic Sized and Rotate on a Dime.
A Piece of FerroMagnetic Material can AMPLIFY the Field of  a Coil by 1,000 to 1,000,000 times without using any extra current !
this torroid contains magnetic domains not premagentised magnets.
for this next bit you may need some research on magnetic domains in metals...
Tseung has said it has an extra coil on this torroid - if one coil has a small amount of current running through it constantly this turns the whole torroid into a mini weak magnet (the domains are biased) and all the other coil has to do is give a pulse and the domains start to precess (a 3 dimentional term for swing). try it with a compass, have a ceramic magnet to bias the compass (or the earth field even). by the way, magnetic domains in metal will not point to the magnetic source like the compass does, they will point randomly but more in the direction of the field (to maintain an average), so add another magnetic source for a moment but beside it and you will notice the swing, it momentarily points to your new magnet and then go back to the other (more random position) but it overshoots and swings till it points back. it will swing faster if your ceramic magnet is closer or stronger - same as with the coil strength on the torroid.
the domains also tend to flip suddenly and this should enhance the effect (in steel, not sure about torroids).
what you have here is a micro motor (if this theory is right and the design works), the coil with the LED captures the backemf and the precession energy. but i have mentioned already that other inventions in kelleys book work on this same process so dont limit yourself to what you think tsungs desing is.
as for the other thing
it requries energy in order to enlarge the field in a coil, and it requires more energy to enlarge the field in a coil with a core to the same point because there is greater magnetic capacity. i am unaware of any amplification (if you bring a metal close to a magnetised core, does it consume more now it has greater capacity? i dont know). i do know that when you put a metal close to a magnet it turns the metal into a magnet (which is why they attract) and so the magnet becomes stronger.....
Charlie.
XS-NRG
Yes he thinks he can amplify something by 5000 without increasing input  :D
What a Clown
chrisC
Quote from: ltseung888 on December 27, 2010, 01:56:50 PM
Thanks to the Almighty.  The Energy Crisis is over.
Thanks to the Almighty, we have mental institutions for the mentally challenged.
cheers
chrisC
