Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 215 Guests are viewing this topic.
otto
Hello all,
@The Observer
yes, this is a picture when a square wave hitts a coil with MOSFETs connected in a classical way.
Thanks, very nice picture.
Otto
ltseung888
Patent by Kwang-jeek Lee of Korea
http://www.free-energy-info.com/Chapter3.pdf
On page 3-64 of the Patrick Kelly eBook shown above, he described the invention by Dr. Kwang-Jeek Lee of Korea.  The US patent application is 2008/0297134.  The title is: Circuit for Transmitting Amplified Resonant Power to Load.
We are trying to experiment to determine whether we can DC Pulse the Primary Coil of a Transformer to lead-out electron motion energy to the Secondary Coil.  The Secondary Coil is a resonance circuit.  Our load can be a resistor, a light bulb, a motor, a capacitor, a HHO cell etc as part of the resonance circuit.
It looks like similar experiments have already been done by Dr. Kwang-jeek Lee.  He basically put a resonance circuit between the Power Source and any Load.  It is good news for me as the Lead-Out Energy theory is once more confirmed.  It is bad news for some of the “product manufacturers” as they may have to deal with this patent.   At present, the patent is only an application.  The US Patent Application date is 12 April, 2008.
In any case, we shall continue to have fun doing the research and benefiting the World.  The pressure to produce experimental results is off.  The focus will shift to a good educational course on Lead-Out Energy! ;)
ltseung888
Quote from: The Observer on March 31, 2010, 12:33:10 AM
LT,
Patrick Kelly does not know what he is talking about... when it comes to your inventions.
You should probably let him know that a sine wave and square wave are two different 'balls of wax'
                     from the perspective of a A.
               (otherwise known as a fancy electromagnet).
The Observer
Thank you Observer and Otto.
I shall have a Pulse Generator and an Oscilloscope to experiment in the next few days.
Thank you for pointing out the waveform that I should expect.
Patrick was trying to show my theoretical concept:
Whe we have diodes on both the Primary and the Secondary side to force the Pulse to be DC, the magnitude of the current will be affected in different ways.  The rectangular input waveform from the signal generator may not be seen as such on the scope.
I believe the Stanley Meyer diagram also show such conceptual waveforms.
The Observer
LT,
Good luck with your new experimental equipment.
The Observer
otto
Hello all,
@Itseung
if you allow just a short one:
if you want that your device uses the benefits of "mother earth" then you have to connect your MOSFET ot transistor( if you use 1 or more) in a high side switch manner. If not, then its enough to connect in a classical way.
Otto
