Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 78 Guests are viewing this topic.
ltseung888
Control experiments are done first.
The first control is to check characteristics fo Pulse Generator with Multimeter that can display waveforms.
ltseung888
Control Experiment 2
Check readings with Secondary Coil Open.  Not connected to anything.
ltseung888
Control Experiment 3
Checking Output.  It appears that the loss across the transformer is small.
ltseung888
The first important experiment.
With a LCR resonance circuit at the Secondary, the measured peak-to-peak Voltage changes considerably,  The peak appears to be around 15,000Hz.  That is very different from the expected 1863Hz.
This may be due to the very different actual Inductance value when we use a transformer.  This will need more research.
ltseung888
The article submitted to Wall Street Journal Asia for the Innovation Award 2010.
It is in two files as this forum does not allow file size larger than 300KB.
