Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
FatBird
@ itseung888,   The picture is getting clearer and clearer in my mind.  The research will focus on the Toroid.
I am glad you are changing your focus to the TPU because WE NEED SOME NEW THOUGHTS on it.  People here have been working on it for 3 years with NO success.  Looking at it, it seems so simple with no moving parts.
Below are some weights & measurements related to his TPUs.
12 Ounce Open Unit in the 38 Min Film.
OD = 6 inches.
Height = 2 inches.
Thickness = 1 inch.
Output = 186V @ 5 Amps.  7 Amps with a Heat Sink.
Small 1 Pounder, Open Coil.  Took Magnet from his pocket.
OD = 4 inches.
Height = 1 3/4 inches.
Output = 100V @ 1 Amp.  7.3 Hz & 5 KHz.
5 Inch Unit evaluated at U of C, by Dr Schinzinger
Date:  12-12-95
OD = 4 ¾”.    ID = 3 ”
Thickness = 7/8 ”
Height = 2”
Weight = He said Very Light.
Output = 137 V at 1 Amp through a 100 W Bulb.
Luminescence Meter Measured = 2.5
15 Inch Unit evaluated at U of C, by Dr Schinzinger
Date:  12-12-95
OD = 15”.    ID = 13 ”
Thickness = 1 ”
Height = 4”
Weight = He said about 6 pounds.
Output = 614 V
Small Open Coil, 1 1/2  Pounder:
OD = 6 inches.
Height = 2 inches.
Thickness = 3/4 inches.
Output = 120V @ 5 Amps.  7.3 Hz & 5 KHz.
Large 17" Open Coil.
OD = 17 inches.
Height = 4 inches.
Thickness =
Weight = 6 Pounds.
Output = 830V @ 10 Amps.
FatBird
SM made the above 8 inch TPU using some PLASTIC RINGS from the Commercially Manufactured Plastic Speaker Unit shown below.
If you look carefully between the cracks, you can see the SPEAKER sitting there inside the rings.
So the Bottom Line is that all of SM's TPUs are AIR CORE UNITS, with NO FERRITE or IRON cores.
Here is the LINK for 1 of his VIDEOS:
http://video.google.com/videoplay?docid=-1944827568401901581&q=overunity&hl=en#docid=167210479374903373
FatBird
Notice the FIBER Speaker Ring SPACERS between his fingers.
ltseung888
Quote from: FatBird on May 02, 2010, 08:41:56 AM
Is it reasonable to use air core in the Toroid?
In the Lead-out Energy concept, we rely on the flux change.  With air-core, the flux change will be most rapid.  There is no prolonging of the magnetic effect at a certain point as soon as the pulse is stopped.
Getting or making a pile of plastic rings with spacer is relatively easy.  The secondary coil can be the continuous, relatively thick coil surrounding the entire circumference.  The primary coil may have much fewer turns, also with thick wires.  Even with a small Input voltage of 1.5 Volts, the Air-Coil Transformer can step up the voltage considerably.
Most electrical engineers will ignore the Pulsing Frequency â€" assuming that it would have no effect.  We have now proven theoretically and experimentally that the pulsing frequency will be extremely important in leading-out surrounding energy.
The Pulsing can be done via an external signal generator, an oscillating circuit, a reed switch or some mechanical means.  My gut feel is that the Steven Mark TPU uses reed switches.  The oscillating circuit somehow drives the reed switches at the resonant frequency.  That leads-out (or brings-in) external energy from the environment.  From reading the background of Steven Mark, my gut feel is that he is not an electrical engineer and cannot design sophisticated circuits.   (That is not surprising â€" as trained electrical engineers have never been taught the concept of leading-out energy.  They automatically regarded bringing-in of energy from the environment as heresy.  Not only would they NOT work on it but they might also laugh at others who “wasted” time on such stupid and fruitless research.)
Our experiment is likely to be:
1.   Use air-coil toroids with diameter of around 16 cm. (approximately 6 inches)
2.   Secondary coil will cover the entire circumference.  Use 16 gauge wire.
3.   Primary Coil will have much less turns. Use 16 gauge wire.  We may have it in multiple sections to produce a more uniform puling field.
4.   The initial tests may use a signal generator and an oscilloscope to study the characteristics.  The effect of the number of turns and sections of the Primary Coils can be understood.
5.   The actual final configuration is likely to be reed switches, some type of resonant circuits and a starting battery.  The starting battery may even be removed when resonance and feedback were successful.
@Fatbird, from your involvement with the TPU, do you know of any one working along such thoughts?  What kind of results did they get?
FatBird
Itseung888,  I just started a NEW THREAD on what we know so far.
Please click on this link to see what we know.  So far, nobody here on O/U has been able to make one.
http://www.overunity.com/index.php?topic=9127.0
I am glad you are interested because we need some new thoughts on it.
Thanks.
