Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
ltseung888
Achieving Overunity via Pulsing Resonant Circuits
The task is not easy.  One must develop the skills to select the right components and the building techniques.  Some luck is also involved.  without the dogged determination, one is unlikely to succeed. ;) ;)
ltseung888
Recharging of non-rechargeable, "almost dead" batteries
I used my Joule Thief Charger to recharge non-rechargeable, almost dead batteries.  That was suggested by many postings on the Internet.  It is supposed to be impossible.  I first encountered that with the Joseph Newman Claim related to his invention.
Now, I am a believer - as I can do it with a less than USD10 investment.  The LED kept going out at the beginning.  I kept trying by keeping and tightening the connections.  After about 3 minutes, the LED was steady.  The voltage across the "almost dead" battery began to rise.
Energy from the environment must be coming into the system.  The voltage across both the charging batter on the RHS and the weak battery on the LHS were not steady DC.  Need to research more.
ltseung888
Checking the battery waveforms
The first picture is the waveform of the source battery.  It is NOT steady even though the meter is place across the two ends of the battery directly.  Some fluctuation or oscillation of voltage is evident.
The second picture is the waveform of the battery to be recharged.  The voltage across the battery is also fluctuating.  Some fluctuation or oscillation voltage is evident.
The next step in the research is to check the frequency of this fluctuation.  Can the fluctuation be increased with different toroid size, material or number of windings?  Will the addition of capacitors affect the waveform?  Is it possible to achieve a resonance condition that can conclusively demonstrate overunity?
ltseung888
The next set of experiments
Now that the basic Joule Thief and the modified Joule Thief charger worked, what should we do next?
It is clear in my mind that the Joule Thief can be made into a Lead-out Energy Device drawing energy from the environment and demonstrating overunity.
We cannot modify the frequency of the transistor easily.  However, we can add capacitors to turn the Joule Thief into a LCR resonant circuit.  We can do that for both the input and output.  We can change the core material and core windings.  That is expected to be a major factor in achieving resonance.  We can even try air core â€" making the toroid an effective TPU.
I shall attack the problem in two fronts.  The first front is air coils.  This can be achieved by winding on plastic rings or hollow discs.  I have a gut feel that we can retain the Basic Joule Thief functionality.  At the same time, we may be one step closer to the TPU.
The second front is the LCR resonant circuits.  I shall use the Gadgetmail Overunity Prize Entry as a starting point.  If it works, the Prize Money should go to Gadgetmail to help his cancer treatment and enhance his reputation.
We must be guided by the Almighty.  How can old shaky hands and eyes that need magnifying glasses to read newspapers achieve such successes?  With the continued blessing, FLEET will come out to benefit the World.
ltseung888
Experiment on May 9, 2010
The air core experiment was successful  I used two "rubber washers" instead of the ferrite beads.  All three cores shown were successful.
This means our research is going a step closer to TPU.  I shall try to use air core for the coming experiments.  This means looking for plastic rings or discs (or washers).
