Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 217 Guests are viewing this topic.
e2matrix
Yes congratulations ltseung!  It sounds like you are right on track and making great progress.
steeltpu
Quote from: XS-NRG on July 19, 2010, 06:42:08 AM
The TPU is not a OU Device.
Surely there are others that are but not the TPU!
Steven never said the TPU was a OU device.
In fact HE SAID IT WAS NOT!
So if there is anybody being misguided, it is you.
And you call the truth the biggest load of crap....go figure.
This only apllies to the TPU, not to the other great inventors i mentioned in a previous post.
And it's not a philosophy.
It also works on people who do research for themselves and think the tpu is a OU device because they can spend as much money as they want, just to find out it isn't going to work.
Go away kid.  You bother me.
ltseung888
Quote from: FatBird on July 19, 2010, 08:26:56 PM
That is SUPER Lawrence.  Thank you for sharing your data to help the world.
Is your TPU (Toroid) Air Core or steel core?
Thank you sir.
Air
ltseung888
Plans on July 20, 2010
1. Build the battery recharging circuit.  From the Output Power figures, recharging an AA battery should be no problem.
2. The challenge is to have the auto feedback and recharging circuit.  We may have Battey A supplying power to a couple of LEDs and recharging Battery B.  At appropriate time, Battery  A and Battery B will be swapped.  Theoretically, the LEDs will light forever.  No additional batteries are required.
3. We may even be able to take out the batteries after starting.  That will happen after we have successfully identified and controlled the resonance environment.
4. If time permits, we shall try to increase Input Power with different transistors. (2N2222 upgrade).
5.  More tests will be performed on the three layer toroid.
The Observer
Tseung,
Two things,
1. It may take quite a bit of extra energy to charge a battery.
    A super duper ultra fancy smancy capacitor would probably be more efficient at recovering extra energy to be cycled back.
2. Although I believe resonance alone will cause an overunity effect,
     I am astounded that a simple piece of iron will magnify the coil's field 5,000 timies !
     Aren't you?
     It is the crashing magnetic field of the Ferro in a Joule Thief that causes the spike.
     That is, the dipoles are moved by a  Quantum Energy called Anisotropic Energy back to random domains.
     THIS IS WHERE THE ENERGY FOR THE SPIKE COMES FROM !
     I'm pretty sure we want to get the unpaired electrons present in Ferromagnetic Substances
        with Low Magnetic Coercivity involved in this party !
      The below diagram should demonstrate my concern. ;o)
Best Regards,
                        The Observer
