Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
ltseung888
The 10 cm air core toroid
I decided to experiment on the 10 cm (4 inch) diamete toroid.  I used ordinary household lamp-wire and wound it on the circular ring of sticking tapes which I happened to have.
The experiment was successful.  The LED lighted brightly.  It looks more and more like the TPU now.  The electronics so far are tiny and could be hidder easily behind the green tape.  It is a matter of getting the correct resonant circuit for Input and Output.
The next thing to try may be a step-up transformer arrangement.  The Basic Joule Theif Circuit will be modified.  The 1.5V DC Input will be stepped up to at least 15V and see if charging of 12V batteries are possible.
Pirate88179
Lawrence:
Good to see you again.  With that sized toroid you can easily get over 2,000 volts, with the AA battery input.  I have done this, Jeanna did it first and then Lidmotor.  It is a matter of tuning your circuit to the toroid to hit resonance.  Check out our Joule Thief topic to see detailed information on how to do this, or PM me and I will try to explain it if you need me to.
I have be fascinated by this circuit for years now.  It is so simple and basic yet just look at what folks have been able to do with it.  I thought I was in the lead lighting 400 leds from a single AA bat. and lighting a 48" long tube but now many folks have surpassed me.
I really believe we are just in the beginning stages of understanding this circuit.
Tell Forever I said hello.
Bill
kampen
Dear ltseung888,
I appreciate your effort, in explaining step by step. Thanks for all.
Paul-R
Quote from: Pirate88179 on May 09, 2010, 07:31:05 AM
Lawrence:
Good to see you again.  With that sized toroid you can easily get over 2,000 volts, with the AA battery input.  I have done this, Jeanna did it first and then Lidmotor.  It is a matter of tuning your circuit to the toroid to hit resonance.  Check out our Joule Thief topic...
...by which you mean this, I presume:
http://www.overunity.com/index.php?topic=6123.msg240847#new
Bruce_TPU
Quote from: ltseung888 on May 09, 2010, 07:23:29 AM
Looking like a TPU and FUNCTIONING like a TPU are "worlds" apart.  Steven Mark Powered banks of bulb, drills, tv's etc., all at the same time.  Lighting an LED is fun, but never to be compared to a Toroidal Power Unit.  Sorry.
Cheers,
Bruce
