Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
tagor
Quote from: Charlieb000 on December 27, 2010, 03:53:34 PM
i was assuming you would google it
http://www.youtube.com/watch?v=gC6Qlj1Mbo8
hopefully my response is not too confusing, if it is then dont worry about it, this topic isnt about the 2SO:
as for "force is not energy", people think its gravity that makes it work - gravity is a force and accumulated it has energy. but i dont think its gravity.  i think its the force that the link refers to. this "psuedoforce" occurs naturally due to the pendulum constantly accelerating on the pivot point. they call it psuedo (false) due to the other force (meantioned there) which is a true force (that is equal and opposite to the psuedo) which is observed. but there is no observed work done by this psuedo force therefore its false to them. the 2SO makes this force do work and you can use formulas to find the useful work (energy) output. the pendulum keeps on moving due to the conservation of energy (if you want to make it more efficient, make it saucer shaped to make it aerodyamic) and its swing is not effected  by the load - or a little bit i guess depending on low loading (I/O on FE devices are never completely isolated). it is also due to the conservation of energy that these two equal and opposite forces occur in order to rotate the mass around a pivot.
what is being done is that the output is leached energy from the de-aceleration of the pendulum in one direction and while the momentum is removed the pendulum accelarates in the new direction.
i cant really explain it plainer than that.
Charlie.
yes I understand ... it is not scientific ... you have to believe it !!
ltseung888
The planned six conclusive experiments in 2011 to be done in USA
1.   Two or more tuning forks in resonance or sympathetic vibration.  The sound produced by two or more identical tuning forks sound louder and lasts longer than when one is struck alone  The question is - where does the extra energy come from?   The Tseung hypothesis states that the extra energy comes from ordering the random motion of the gas molecules to a pulsing order.  The gas molecules have kinetic energy according to the well accepted Kinetic Theory of Gases.  This means that even when sound travels through air, the pulsing or vibration orders the random motion of the molecules and leads-out or brings-in the kinetic energy of the gas molecules.  This gives us a new understanding of resonance.  External energy is brought into the system.  This confirms the correctness of the Lead-out or bring-in energy theory.
2.   Leading-out or bringing-in gravitational energy.  The conclusive experiment was first observed by Mr. Lee Cheung Kin in December 2004 when he stared at his pendulum swinging toy.  Mr. Lawrence Tseung did the mathematics and concluded that two part of horizontal energy can lead-out one part of vertical or gravitational energy. So long as there is tension in the string, gravitational energy can be lead-out.  The swinging pendulum toy from the market is a readily available prototype.  To convert it to an energy extraction device, the amplitude of the swing should be large and operating at the “hitting the rim” positions.  This can be confirmed by the Milkovic two stage pendulum video 6 seen on youtube: http://www.youtube.com/watch?v=gC6Qlj1Mbo8
3.   Leading-out or bringing-in magnetic energy.  If we can lead-out or bring-in gravitational energy from a pulse-pushed pendulum, we must be able to extract magnetic energy from a magnetic pendulum.  This is the famous Ms. Forever Yuen magnetic pendulum experiment.  The ordinary pendulum was replaced by a magnet.  Another magnet is place below it to provide either an attracting or repelling field.  The period of oscillation will change.  A magnetic field is much easier to control than the gravitational field.  We can change its direction, its magnitude and even turn it on or off.  The smallest magnet comes from the orbiting electron around the nucleus.  There are trillions of atoms (and hence electrons) surrounding us.  If sound resonance can lead-out or bring-in the kinetic energy of the moving molecules, electrical resonance (LCR resonance) should be able to bring out the electron motion energy of the atoms.
4.   Listening to the sound energy of a resonating transformer.  This conclusive experiment will be defined and directed by an overunity.com forum member â€" Observer.  When one designs a transformer, one should avoid the resonance condition.  In this case, Observer deliberately sets the vibrating source frequency to that of the transformer or toroid.  A loud noise is heard at the resonance frequency.  No sound will be heard at a higher or lower frequency.  Approximately the same electrical energy is supplied at different frequencies.  This can be explained from our understanding of the swing â€" if the pushing is not at the correct time (or frequency), the swing will not go very high.
5.   The pulse rotating wheel. The pulse pushed oscillation motion can be changed into a rotational motion to achieve a much higher efficiency.  This can be demonstrated in the Tong or the Bedini wheel.  Mr. John Bedini demonstrated a large fourteen feet wheel and got the participants to build a small 3 magnet device at the Bedini Ferris Wheel Motor - at  the Renaissance Conference - November 14th 2010. See http://prezi.com/pmtiqicgve1z/bedini-ferris-wheel-motor/
6.   The FLEET (Forever Lead-out Electromagnetic Energy Transformer).  If we can lead-out electron motion energy via moving devices, we should be able to do the same with flux change devices.  The initial idea was to experiment with a “Pulsed DC transformer with Embedded Magnets”.  That has evolved to the more general LCR resonance tuning on toroidal transformers.  The pulsing was done with a Joule Thief Circuit.  This is probably the cheapest demonstration device.  The components cost less than USD3 and can be purchased or ordered on-line.  The prototypes can be tuned with the help of two oscilloscopes displaying the instantaneous Input and Output Power waveforms. This experiment is being verified in multiple locations at present.  COP (peak-to-peak or rms) > 200 has been achieved.
With Blessing from the Almighty, these six conclusive experiments will convince the scientists to do more investigation and research.  The Lead-Out or Bring-in Energy theory will be accepted.  Practical Machines will be built to benefit the World.
XS-NRG
yes you plan and plan, but what happend to mister ping wang ho from the wang jong university?
Quote from: ltseung888 on December 28, 2010, 10:33:04 AM
HAHAHAHAHAHAHAHAHAHAHAHAHAHA sure
DELUSIONAL CLOWN
I think you will have a bad taste in your mouth when you get to speak to the almighty....
The Observer
Charlie,
Quote from: Charlieb000 on December 27, 2010, 04:18:49 PM
this torroid contains magnetic domains not premagentised magnets.
as for the other thing
                                   i am unaware of any amplification..
Charlie.
That you are aware of magnetic domains is impressive.
However, you seem unaware of what they are made up of and why they act like they do.
A Brief Summary of FerroMagnetic Materials
1. Unpaired Free Electron Spin in FerroMagnetic Materials Produce an Atomic Sized Magnetic Moment.
2 .These Atomic Sized Dipoles line up to their neighbors when they Newtonianly shouldn't. (dipoles should skew in close proximity)
   - A Quantum Energy called Anisotropic Energy is Responsible for this Anomaly.
3. When Many Millions of Atoms line up in a 'Domain', they react with the neighboring domain in the Newtonian Way (they Skew).
4. The Boundary between Domains (consisting of the atomic dipoles lined up when they shouldn't) is called a Bloch Wall.
     - The Dipoles form a Soliton Standing Wave between Domains.. see pics below.
5.  A FerroMagnetic Substance has a HUGE Internal Magnetic Moment as a Result.
     - This Magnetic Moment is reflected in the Parameter known as Magnetic Permeability.
6. The Magnetic Permeability is what lets you know how much a Coil's Field is AMPLIFIED (multiplied if you wish)
    - The Following is the Formula for the Magnetic Field of a Coil.
        B = (μ0 * μr * N * i) / l
               - μ0, N, i and L are constants for any given coil with a constant current.
               - μr is the Magnetic Permeability of the material within the solenoid. (99.0 % of all substances are ~1, Ferros are ` 500 to 1 Million))
      - Study the formula closely, it reveals that A FerroMagnetic Material AMPLIFIES a Coil's Magnetic Field by 1,000 to 1,000,000 times !
I hope you can see that I have studied this extensively.. and that you realize that Domains are made up of Atomic sized Magnets.
Best Regards,
                    The Observer
Bob Boyce
Consider a unidirectional pulsed field traversing domains at the propagation velocity of a material containing those domains.
Now wrap that material into a loop (toroid) and then consider how much unidirectional pulse energy is required to continue the process indefinitely.
What practical purposes can a ring resonator be put to?
Instead of ridiculing others and calling them names, you people should be doing experiments and testing results. I am amazed at how much this forum has degraded since I used to participate.
I am not sticking up for anyone here, I am just trying to make a point. Do not be too quick to judge others, especially if you have not put forth any effort yourself.
I personally experimented with a small toroidal version of the "joule thief" in 2009, and did note some COP >2.5 results when it was tuned just right. I was not really impressed with the small amount of output, but that's just me. I would not call it a failure, as it did exhibit a COP of greater than 1. I just do not have many applications for milliwatt level power sources.
All of that aside, I have agreed to put Prototype C to the test. Since it looks to be similar to what I have already experimented with, I think that I'll have a good shot at getting it to perform to the best of its ability.
Bob Boyce
