LaFonte Group can turn off permanent magnet without work
Started by Paul-R, March 03, 2010, 06:31:34 AM
0 Members and 18 Guests are viewing this topic.
Butch LaFonte
We ran the new switcher and it turned cog free very easy by hand. When we connected a motor to it and got above 100 RPM the eddy current drag became so strong the motor would strain and stay at that RPM. the eddy current drag in the iron with the 8 magnet rotor was like hitting a brick wall. We got 390 volts AC at 700 RPM.
That's 3342 volts AC at 6000 RPM. So, if we had an eddy current free stator we would get 3342 volts out of a generator with no power needed to turn the rotor.
We will now take current readings and try different types of loads on the coils. We will also power the coils with an external power supply and show there is no effect on the rotor.
We are at a stand still at this point due to no funds for building a zero eddy current stator.
Will post videos on Youtube today of our tests last night.
Butch
Blainiac
I wonder if Stephan will let you dip into the OU prize funds... since you're practically there.    ;D
I conform to non-conformism.
hartiberlin
Hi Butch,
well done.
Looking forward to the videos.
Why didn´t you try to use the black sand from the beach ( black iron oxide)
yet ?
If you can collect it from the beach via a Neodym permanent magnet,
it is free and you only need a binder like hotglue or epoxy glue or simular to put it into a form.
Regards, Stefan.
Bruce_TPU
Quote from: hartiberlin on April 14, 2010, 07:15:17 PM
Hi Butch,
well done.
yet ?
Regards, Stefan.
Hi Butch,
Below is a link to buy some Black iron oxide... Only $7.00 USD
It would be worth a try IMHO.
http://cgi.ebay.com/5-lb-Black-Iron-Oxide-Fe3O4-Used-in-Thermite_W0QQitemZ280351919842QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item414646cee2
Cheers,
Bruce
Butch LaFonte
Testing through the night also. More to come.
Butch
