LaFonte Group can turn off permanent magnet without work
Started by Paul-R, March 03, 2010, 06:31:34 AM
mscoffman
Quote from: Paul-R on March 08, 2010, 12:33:51 PM
If you want to "turn them up", then buy more powerful ones.
The breakthrough will come when the "sticky spot" is removed by turning off the magnet which did good work half a revolution ago, but now is in a N - N position, causing problems.
Also the breakthrough will come when the "sticky spot" is removed by
turning off the magnet which did good work most of a revolution ago, as
it climbed the gradient from weakest to strongest but the strong ones now
don't want to release it across the sticky spot to the weak ones again...
:S:MarkSCoffman
Magluvin
Wow and double wow
That is frikin genius  It makes perfect sense and 110% believable. Zero doubt.
There probably will be a slight attraction to the cores leading out, but I fully see the on and off thing being way more done than what is put in.
This IS the Holy Grail for such a generator.   I am just stoked
I looked at the femm anim first, but the live demo below is key to getting what they are doing.
Love it
Magluvinit
penno64
Cloxxki
Oh please let this work! Should be pretty easy to turn it into an inputless electric engine. Like the Romanians hint they accidentally made in the 70's or so.
Is that the voice of Batgold in the picture with the proto build in progress?
