Muammer Yildiz Magnet Motor
Started by penno64, March 08, 2010, 03:02:32 AM
ramset
would have to be "shaft speed" !
OK ,so take your little flying beasty chain it to the pitnit table ,place a tube over the prop
and play with the output flow ?
Or you could just take your vacuum cleaner and suck up the cat {clog it} or put it on Blow and put your hand on the end.
Listen to the motor ??
does it sound like its coasting??
Thanks Grandma
profitis
yes @tinselkoala but if we just had a infrared snapshot of the whole device we could tell if a battery is embedded in the motor because it would show up as a hotter part of the image where the bats are located.if it showed the case of the motor as cooler than ambient then i would tend to rule out batteries and start to think in terms of a 2nd law violation.
synchro1
We can clearly see someone Laser Taching off the rear section of the axel. Definitly reading shaft speed.
Quote from: ramset on April 11, 2013, 09:40:55 AM
Good thing I don't have a cat, or I'd try it.
No, it doesn't sound like it's coasting exactly. It's not really blazing along either. So, not 5 watts at 1300 RPM, not 14 from punching wrong buttons, but 46 or 61 watts from good calculators based on the prop dimensions and taking the measurement of RPM as correct. I can accept that.
Nine candy bars.
Quote from: synchro1 on April 11, 2013, 10:33:21 AM
Can you give the link to where that can be seen? I can't stand to watch any more of those fracking ads looking for it. This is the most boring demo ever.
