Muammer Yildiz Magnet Motor
Started by penno64, March 08, 2010, 03:02:32 AM
0 Members and 27 Guests are viewing this topic.
profitis
by the way domichi,did you notice that the vast majority of overunity device experiments on this website and other websites are in some way related to induction.there are some very complicated circuits and some very simple ones but all of them point back to the basic coil and paramagnetic core.
CazadorDeTruchos
Have you noticed that @DomiChi and @profitis are always together, almost at the same time? Never one at a time.
They never are separate, always are together defending to YILDIZ´s KIND OF MAGIC.
WILL BE THE SAME PERSON WITH 2 DIFFERENT NICKs.?
Have you noticed that?
Looks like Yildiz´s Team pays very well ...
DomiChi
Quote from: CazadorDeTruchos on April 23, 2013, 09:04:16 AM
Of course, we are almost on the same time line. Near the server time line. With minimum 6h difference with you (you have to know a minimum geography).
I remember to have learn that in one of my first school http://www.mapsofworld.com/world-political-map-2000px.jpg
If you can look where is France, South Africa, and your country.
DomiChi
Quote from: profitis on April 23, 2013, 06:04:36 AM
yes air friction and shaft friction would definitly put a limit on speed of any such device.personaly i believe that if yildiz,s motor is genuine then he must be using either coils or metalic material to self-induct with eddies and change the properties of the magnetic field around each magnet as the other magnet passes by.this is not a simple case of just magnets repulsing each other like so many guys have tried before.we have to look at inductor circuits like rosemary ainslie,or beardin etc and try to find out if the kickback of such inductors is truly is larger than the input.therein lies the clue domichi,if inductors can work then there will be a way for a motor to work because it will then fall in line with the thermodynamics theory of steven.j.smith(google steven.j.smith magnetothermodynamics)
Another thing that is genuine is the double rotor, with the inside rotor creating magnetic dynamic for all the engine. Effect creating condition for the cause is not usual. Only quantic physic already admit that ("gomme quantique" (quantum eraser)).
shadowpt
Quote from: DomiChi on April 23, 2013, 03:50:41 AM
Shadowpt first posts on this forum were to say that he did succeed with his project. But as Yildiz succeed, he moved on this thread, and he already decided that as he did not succeed himself, other cannot. This post bellow post was before Geneva demo.
But Shadowpt project was only on FEMM. I know myself, for having maid prototype, that FEMM give not always the good answer. And I have seen some posts saying the same.
One off the wrong said from others, Shadowpt does not know magnetic viscosity (known since 1895). Google"ewing magnetic viscosity". And also do not know that friction torque increase with speed, like Foucault effect (3 mains reason to self limiting speed).
I have another brain schema. If I do not succeed, what can I learn from Yidiz? 30 years of observation is not nothing.
I already have seen good ideas from Yildiz, but it is complicated in DIY. I want to try to do something easy and cheap to do at home if possible. There is a lot of good ideas on Internet. A lot stop before any prototype, and any proof that it will not work (R.Calloway has some that he let us try). And if I cannot succeed with magnet, I will try Schauberger hydro turbine, and R.Vialle principle. But I will not consider magnet as scam. Just, magnets need more precise conception and adjustment that I did.
Oh silly DomiChi, you still don't read what is being written, in my posts I express my skepticism as to why are my results showing overunity when it clearly shouldn't , I even say that I have been studying the most common configurations to understand how they work and that all of them should always return a net result force of 0, the 2 that I found were providing a different kind of result, one I already figured out and the other I am still trying to find my mistake so I posted here to get help from anyone that might see the mistake better than me.
You would notice that right away if you even checked the title of those threads:
"Requesting decent analysis on FEMM simulation data"
"Need some help with magnetic field simulation data analysis"
Do you know what "analysis" means?
Yet again you don't even read what you talk about, childish domichi :D thats the problem with taking things out of context.
QuoteOne off the wrong said from others, Shadowpt does not know magnetic viscosity
And after reading with more depth about the testimony of Allan I noticed that he had pancake coils to controll the maximum speed of the machine, which I even posted after
Quote from: shadowpt on March 19, 2013, 11:44:03 PMAs I said before (only one thing I withdraw which is the coils that are used to limit the speed which I confused with electronic dyno limiters that I averiguated after checking the full machine declaration)....
So, now that this is clear for you that DomiChi has no clue about research and just keeps taking things out of context, what will your big next step be?
I wonder how your magic machine will change the world, do you too want millions for your world wide patent?
Silly DomiChi, you keep trying to play this game but you keep losing everytime, it is so easy!
And remember, at least  I studied FEMM so I could try these things myself and learned it so I dont need to rely on the time of others, what have you done?
Quote from: DomiChi on March 16, 2013, 08:26:41 AM
Hello everybody
In this document http://www.nuenergy.org/theoretical-self-sustaining-permanent-magnet-motor/ we can see a diagram where we can think that with this magnets configuration we obtain a rotating field.
I am not a magnetism specialist, is there somebody who can confirm that?
A FEMM simulation will be OK for me, but I don't know how to in FEMM.
Can we obtain the same with flat magnets (easier to find, this one http://www.supermagnete.de/Q-40-20-05-N for example).
Thanks in advance
Domi
Oh domichi, I guess you still keep proving that I am better than scoundrel like you ;D
You just said that you are not a magnetism specialist but you keep telling everyone that you know all about it, what a delusional child ;)
I am curious, can you find another wrong? Or you will just make up fake words that I never said again? Now that is calumny, the same thing that you accused me of before, except that I have all the proof for my accusation, what do you have for yours? :D :D :D
DomiChi 0 - 15 shadowpt
I am still winning ;)
