Muammer Yildiz Magnet Motor
Started by penno64, March 08, 2010, 03:02:32 AM
truesearch
@DomiChiP:
Schauberger has been an interested of mine for a long time. I would like to see your work and experiments with the "Schauberger-Vortex". Do you care to start a new thread here and share your discoveries?
truesearch
DomiChi
Quote from: truesearch on April 25, 2013, 10:41:29 AM
@DomiChiP:
truesearch
I already have done the mold for making the vortex which will support the pipes, but I stop because it was the winter here in France. And I didn't want to play with water when it was so cold. Then I chose to try magnet during waiting sun. But sun is coming. With magnet I think there is only a working one that we can do ourself, it is the steorn Orbo, like Naudin replication. Yildiz is to complicate to do it at home (he has to make us a kit), an Johnson use out of age magnet. But Steorn is not magnet but electro-magnet. With Schauberger repulsine we also to have a motor. Magnet motor had been a good chalenge.
We allready have threads on Magnetosynergie and Quartz already work a lot on air turbine http://www.magnetosynergie.com/forum/viewtopic.php?f=9&t=33. What I already discovered is that the vortex cone is not exactly like the mathematic model. I use the real one to make my mold. But you know that north and south of earth have not the same one (not in the same direction), then the turbine have to take that into account.
A good doc is http://www.incapabledesetaire.com/edito3/enerlib.pdf, take time to translate it with google. You will discover that since 3000 years OU is hidden. And a lot of other usefull informations, also that conchoid is OU.
truesearch
@DomiChi:
Thanks for your reply. I visited your thread on Magnetosynergie but I can't read French, and Google-Translate isn't very good. . . .
I hope you share your work here on overunity.com.
truesearch
DomiChi
Quote from: truesearch on April 25, 2013, 01:35:50 PM
@DomiChi:
truesearch
Yes if I have results. I do not want to be like the pugs. It is not because I not succeed that I will say that Schauberger did not work. But just that I miss information.
profitis
@domichi,i was checking out the naudin experiments on r.vialle,very interesting.unfortunately i cant post a link to the vortex site because im typing through a cell fone here under opera mini compression but you can google 'vortex-l' and it will show you the link.some very respected physicists and ordinary guys discuss anything and everything on there from zero point to cold fusion to any topic much like here.i was thinking of another way to create a steorn-yildiz type engine without any batteries that might work: if we throw away the toroids/coils and replace with a weak paramagnetic metal e.g. aluminum disks or manganese disks..then when the magnet accelerates towards it a eddy current induction and lenz repulsion at critical moment happens to let magnet pass.very strong neo magnets should be able to do this and it might be key to yildiz secret,its worth testing because no  circuit required.
