Muammer Yildiz Magnet Motor
Started by penno64, March 08, 2010, 03:02:32 AM
DomiChi
@profitis: "Neon" light produce more lumen than led for a same consumption.
Have you a simple drawing of your battery. By MP if you prefer. Now I have no time, otherwise I'd well try this self powered Neon lamp for my bungalow. But I will have time after my magnet motor (it progresses, I succeed in broking stick point without energy consumption), but my generator will be more for the 220V refrigerator.
markdansie
Quote from: Cisco on May 02, 2013, 01:26:15 PM
Mark Dansie,
Please confirm whether the buoyancy device you referred to is indeed the one promoted by Wayne Travis, as suggested by TK.
Thank you,
Cisco
Yes it is. However there are some good people and qualified engineers working on this with Wayne so I do not want to discredit them. They still intent to build a proof of concept device (self running I hope) to pass the test i set for them some two years ago. Also another engineer friend of mine and some of his buddies are yet to be convinced. Time will tell, but two year on it becomes more doubtful.
I will say i did see back two years ago a demonstration where pressures did hold after running for a short time. That influenced my decision to be open ended with it. However since then no data other than speculative has been produced.
MileHigh, MarkE and TK along with many others were right to be critical of me, however not for the reasons stated in some cases.
I still wish Wayne and his team well and hope they move to a working proof of concept sooner than latter. I think they are jumping the gun a little in other areas how they are progressing their business.
Kind Regards
Quote from: webby1 on May 02, 2013, 09:12:59 AM
Again you missed the answer there TK,, you are the one who does the work for those private investors,, the ones you want to take the next best thing since sliced bread to in hopes of being funded for the research and stuff and then be the first one to publish a paper on it,, right, that is what you have said,, so when you get a GIG,, that would be WORK TK .
And again you are misrepresenting me and what I said. Get your facts straight, Webby, please.
Yes, I keep my eyes on this and other forums on my own time for something that LOOKS REAL, so that I might be able to present it to some people that I know, who would then look more deeply into "it" whatever it is and help to develop it with full IP protection for the inventor, and possibly even lots of real monetary support, and if I am the one who finds such an idea and presents it, then it will have a better chance of making it thru the door and being seriously considered. Then, and only then, might I myself benefit in any financial or academic way.... and so far there has been ZEEEERO, none, nix, nichego contenders. I began investigating the Travis claims when I was told that he had a PATENT. And that was the first lie that I uncovered: he had no patent, only an application, and the application didn't include the detail necessary for a person skilled in the art to reproduce a system that met his claims. Needless to say, the "friends" that I had spoken to about Travis gave me a big razzing about that one.
Well,, I understand this part, and yes there are many frauds out there and yes most of them follow a pattern and most of them also seem to fall of the face of the planet when the "trick" is shown.
Again TK,, what with asking me this question??  What with trying to make me look like something I am not for not giving you the answer to this question??
You aren't answering the question because you still seem to have some faith in Travis, and yes, I contend that the two thousand dollars he gave to you have some little role in preserving your faith.
I built a water pump that pumps water up over 12 feet,, the nifty thing is it has 1 moving part and only builds up 3 psi on the discharge side,, that I have answers for,, stuff that I have for myself.
What is its power supply? Does it run itself? Or is it like my Perpetual Water Pump, whose _only_ moving part is the water itself (except for the ZED riser of course), which runs on gravitational potential energy put into it during its "precharge" setup period (the same thing that Travis's Zed system runs on)? Or do you have to continually supply power to it while it's pumping a 12 foot head? They are just questions, and they are about your stuff that you have for yourself.
What about that work on precession you were doing,, gonna tell us all about that?
No. But thanks for asking anyway.
I was not aware that I was going to receive any money for the build of TBZED, i did not get informed of that until after I had posted a lot of the stuff I was observing,, so get your facts straight on this.
Where did I ever say otherwise? My facts are straight, I think. Please correct me specifically where I am wrong. I never said that Travis gave you money _before_ you started your work, did I? You cut up some tennis ball packaging, put it together with silicone glue and poured some water into it and made some measurements. Travis liked what you did and how you were talking about it, so he gave you some money. And you haven't had a negative word to say about him since, even though he's been shown many times to be.... well, shall we just say _wrong_ in many of the claims he's made.
Vacuum,, that can really suck :)  was it not you who suggested that the system should be able to run backwards,, and did I not try many things and ways of having it run backwards??  sometimes backwards is not just in the reverse direction :)
I am not in control of your experimental procedure, that's for sure, and therefore I am not responsible for your results, whatever they might be. All I know is that I was the first one to make a "self-powered" water pump incorporating a functioning ZED/Pod/riser assembly, in response to Travis's challenge, and I was the first "outsider" to show some advantage from a ZED. But since I am a skeptic and am pointing out that the Emperor in fact is naked, I got no reward from Travis, only the insults from sycophants like RedSunset, LarryC and others. Including you.
ETA: Nor would I have accepted any money from Travis had he ever offered me any. A prize award would have been gratefully acknowledged, but the money would have gone to a Chickasha no-kill animal shelter or spay-neuter program.
Quote from: profitis on May 02, 2013, 01:36:01 PM
@ramset,my intent here is to tickle tk, or any other alleged boffin here, into an electrochemical arguement on the validity of steady-state-non-equilibrium systems as a permanent voltage/current source,ie.like the experiment i threw at the poster called de truchos earlier in the thread.i want to dance with somebody ontop of the 2nd law thermo lol.i doubt any1 has electrochem knowledge here tho.
I am not qualified to discuss electrochemistry, that's for sure, except on the most rudimentary level.
Are you? What are your qualifications? Got a Ph.D. in electrochemistry from a major research university, do you? I'll bet that is what you'd require for someone to be qualified to criticize your claims.
profitis
@domichi..im glad you bring this to my attention.neon-type bulbs may be the solution to home-light of the masses of poor worldwide.just one shoebox size battery installation may be able to provide permanent lights for whole house.this is where the money is.a diagram is nt necesary as it will look like any battey,paper-thin,flexible high-tech,or normal tube or square multi-pile.it will be cheap too.cheaper than Nicad or lithium ion and easier to manufacture.im start to investigate indoors infrared photovoltaic capture also because i already see a small continuos current in 1 or 2 photoelechtrochemical systems,this shows real promise for continuous uninterrupted energy.if you get that magnet motor moving i hope you will let me work for you in research becoz you wil put me out of buisness lol.
