Muammer Yildiz Magnet Motor
Started by penno64, March 08, 2010, 03:02:32 AM
profitis
@tk.yes that is so true.i dont see where mr travis device can violate the 2lot,have you built such a type device?
minnie
Hi,
   the Tinselzed is impressive, just got one small glitch, after so long it stops! What is baffling is the immense size some
of these gravity machines assume. James Kwok's Hidro, the Travis machine and the  latest offering from Brazil are huge
contraptions, surely a table top model would suffice? Another OTT example is Rossi's 1 mw. plant.
  The small Yidiz motor was exhibiting about the best performance you could expect from a magnet motor, seemed to
me it was just lacking a battery which would probably have kept it turning.
        John.
profitis
 yes ive seen only 2 gravity devices capable of perpetuum mobile,one is simply a long column of air in a long plastic tube,the temperature has been confirmed to always be a few millikelvin warmer at the bottom than at the top due to accelleration of random gas atoms on the downward path but its quite impractical.the other is an osmosis column where the vapour pressure of solvent always exceeds that of the solution  resulting in very slow cycling of solvent,also impractical nonetheless both are direct evidence of 2lot violations.maybe someone will stumble onto more practical means oneday.
DomiChi
Quote from: DomiChi on April 29, 2013, 10:09:19 AM
Best regards MarkDansie.
But I will stay to say to Profitis how we continue on French forum. Yildiz or not Yildiz ?
As I defended the Yildiz principle, I will be not so persevering on Yildiz commercial way.
I wrote in French forum:Translated:I already write to Halli with his form to have better information than on PESWiki, on what is the "open source' plans, I am waiting for answer. If I receive usefull information, I will put it here.
It is a long time ago, and I never had answer. Then I put this commercial offer in the scam box, even if the system works.
PiCéd
For the moment I'm not realy sure of the true but if it work it could be because an electrical connexion between the rotor and the stator.
When I see the video of jrcompiter on youtube, he use conductives materials, so the air must acts like a capacitor.
Then, wait and see.
