Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
Mk1
@all
While charging the batteries , i did test with other dead ones , and got about 19 volts from on pickup coil the inner one , and about 14 from the other (taken with 2n4007 bridge).
I can run a motor form on and a bulb from the other , it seems i should put a new pickup coil with smaller gauge to raise the voltage a bit ...
I connected it with swapped core base coil . I also tested the battery leads i extended it with an alligator clip , and got brighter leds out of the satellite coil .
I can't wait to see what a fresh battery will do , i will hold finishing it for a bit , to see if i should add a new pickup coil ... And i cat wait to remove the pvc pipe.
Mark
Mk1
@all
I made a quick test to see what was more efficient at picking up the power from the battery leads the satellite coil Vs 1000 feet of 30 gauge magwire , so 15 to 20 feet vs 1000 ...
I got no light from the 1000 feet , and 3 leds bright from the satellite coil ...
Mark
Mk1
@all
Test with fresh battery , the 2 volts 250 mili and 6 v 250 mili bulb are working bright...
I can finish the build !
Mark
Mk1
@all
All those bulb i can light pretty bright , except the .8 amp one ...
Mk1
@all
I connected both pickup coil in series and then connected it directly to the meter , i got different readings on all voltage scale except the micro volts dc .
One the micro volts the screen is blinking , i get .75 volt dc to 75 volts dc and 1.2 volts Ac to 15 ac volts .
Lets just say the meter is useless ...
Mark
Edit i test the pickups with a bridge got 35 volts , amp on a 1k resistor .10 A
Btw resistor or not i get .1 A .
