Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
Mk1
Quote from: ElectricGoose on April 11, 2010, 12:32:09 AM
Mark
Not 100% sure what you mean about the whole "removing nails to twist coil and 'second row'".  I think I am confused as to what you are terming as 'rows'.  I THINK I know what you mean.  Sounds laborious though if you are doing what I suppose you are.
Thanks for the reply.
E-Goose
Yep laborious  :D
I do remove the nails and move the coil to the side 1 or 2 degrees to put a second coil . I could not put enough nails in the PVC pipe to make me happy.
I will make a new one as soon as i find the right nails , the spacing is about 4 mm now , it will be 2mm .
@all
I made 3 movies and edited them into one , no audio ...
First compass test , second i will show you what i mean by battery lead power , and last i will charge the .047 farad 5.5 volts cap(it is a bit slow compered to other test i made before)
NEW MOVIE  http://www.youtube.com/watch?v=cJsz2Kd4R7o
Enjoy !
Mark
Edit i forgot the crazy meter video ...
http://www.youtube.com/watch?v=A2r5npBpWpg
Mk1
@all
Yes another one , http://www.youtube.com/watch?v=NfT83_X2B1M
The pvc pipe keep the magnetic field out of the center of the coil , i can't wait to finish the coil to test without it , Also the compass seems to show a rotating field ...
Mark
Mk1
@all
I got a great idea from this video !
Fero fluids are great but not super fluid , but oil and water don't mix , see how that magnetic mass is free in water ...
http://www.youtube.com/watch?v=R-79zcnFfrk
Mark
Mk1
@all
I made a discovery , Stepan asked me once if i could light bulb with two secondary , i don't remember if he wanted with a second bulb at the other ends or open .
So here are the results .
First i can only light them in a closed ends way , when the coil wound in opposite direction clockwise and ccw i can light bulbs at both ends , wound in the same direction i can't ...
Mark
