Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
Mk1
@kooler and pirate
I may get you some screen saver quality picture soon  :D
@E-Goose
Its not a necessary end game for me over unity , to me its more a over use of what i have .
I am how ever interested in your result , would you be kind enough to bring some substance to the claim , numbers maybe photos , and process used to determine the results .
I never constructed anything that was not totally recyclable .
I started with one bulb i could light , now i got 5 it lights a 4v 500 mili bulb , and i can run my bendini fan motor/generator from a 1.2 volts instead of 9-12 volts.
I really don't consider it wasted time , i believe making small steps learning all the way , i do see constant progress.
More detail Please !!!
Kind regard
Mark
kooler
Quote from: Mk1 on May 06, 2010, 12:06:10 AM
@kooler and pirate
kool.. i'll take mine in a 1920 X 1200 res
when you get time..   :D
robbie
ElectricGoose
@kooler and pirate
@E-Goose
Kind regard
Mark
Hi Mark
Sorry, I didn't mean to come across negative or killjoy and I agree with your sentiments.  'Trial and error' experimentation (making things) is NEVER a waste of time, especially when you walk away from the experience learning just one new thing (even if it is how not to make the same mistake again  :D ).
Like you I have been building various coils and slowly the volts climb a little bit with each design.  Some coils you keep, others are real 'Doc Brown' Masterpieces like yours and others you recycle, otherwise after a very short time you have no space and boxes of crazy coils you can't remember did what.
I have messed with the Rodin Type before and when you started posting here I adapted a few older jigs I had and made a couple variants while you were still getting your big jig right.  As previously mentioned I don't have a digi so no pics (sorry) but the diameter is probably larger than yours although NOT as tightly spaced (pegs further apart).  I went for a slightly different approach and wound two internal 'toroids' spaced with a mulitstrand collector coil (8 turns or so), then built two more 'toroids' of basketweave.  I then placed another collector on the perimeter.  After removing the pegs I ran another collector cable through the peg holes.  Its certainly very pretty with all the different cable color  :)
Results -
It runs on very low current and you can crank the resistor at base very high with the led lit at E/C still ultra bright.  This however comes at a cost to the heavy collector coils running between the layers and their output will drop right down
I used my own JT Circuit with Darlington pair (but not the one you posted).
It is NOT possible to reap from multiple collectors AND a central coil within the toroid core.  Using too many collectors disrupts the 'flow'.
The cable which runs through the old peg holes collects NOTHING.
That's all I can think of for now.
Kind regards
E-Goose
Mk1
@e-goose
I never tried led on it , but i can say one thing there are many sweet spots
I should make a video of it , so those sweet spots show the bright light but dim under load , and others don't this is the thing i noticed on one of my first coil , also i don't have the tools to do a proper output reading , i just have a lousy multimeter , that goes crazy on the coil so i use bulbs ...
Mark
Edit
Try connecting a diode full bridge between both transistor collector , check the output there ...
I am quite surprised you got it working at low amps but the fun is higher , what transistor do you use ?
But all and all , the jt never was claimed as a OU device , my coil used for many more experiments on the tpu ...
Mk1
