Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
Mk1
@wattsup
I agree that if the theory hold valid , that would be a good way to go about it.
Thank for the drawing you made it very clear.
@all
I still have issue to iron out , 1 of my main prototype is giving me more output with some load on the transistor , it is not the most powerful but is the most promising to that fact alone , i have yet to isolate the reason for it . Some of my leads are the secondary is spaced between the winds ( it would agree with Ag theory) , it may also have to do with some randomness i added to the windings , also there seems to be some think undeniable the fatter the wire on the pickup coil the more amps seems to come out. There are many type of winding to consider not only there location , i wish to see if i can get power from a coil outside the one i already have on. Those two coil could be then connected in series , pancake , mobius i already tested some of that seems to load even less the transistor , And so on . :)
@all
Here are the first two prototype i made , i started with the idea that you could make a JT from wires only no core .
And then on the second one i got the same idea Wattsup had .
Mk1
Quote from: ElectricGoose on March 11, 2010, 06:12:41 AM
Great job Mark!
I was wondering about your pickup coil.  Is that a duplication of the "agentgates" (angled wiring) or are you merely tapping voltage from a 'straight simple wound' air coil?  How are the Led's tapped onto it?  Are you utilizing any other components?
E-Goose
I think you speak of the satellite coil , i hope i am right .
http://www.youtube.com/user/abramrk1#p/u/2/U9BMTAlL0dU
The satellite coil is actually a fabrication reject , when i started making the Micro version this was the first one but the edge is kinked so i made a new one that became the green and white one , so it is the exact same geometry but only one wire.
The 3 led on to are from one of those dollar store lamp , i removed the 3 aaa and one resistor and soldered it to the coil direct to it.
Its very free and useful because it shows visually when the transistor is under load form the orbit pickup coil.
I also used at first the other coil made from over 1000 turns of 30 gauge wire. The other coil is so much better.
You can see those used in my first 2 video .
http://www.youtube.com/user/abramrk1#p/u/4/OyiY-N1Ha5A
http://www.youtube.com/user/abramrk1#p/u/5/Glg8ZWntnAo
Mk1
@all
More pictures of another prototype .
Also the satellite coil managed to pickup the field around a ferrite toroid Jt no magnets.
The bright light is 24 led in parallel .
