Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
skippula
Mk1
Sir your workmanship Is amazing!
you must have the patience of a saint !
Mk1
Quote from: Magluvin on March 12, 2010, 10:13:25 PM
Hey Mk
On that last pic, it looks good and tight. I always wondered if you had another secondary inside also, if the polarity of it would be in the opposite direction of the outer secondary. By the looks of it in relation to the primaries, it seems as if it would be just as effective as the outer secondary. So I wonder if it would take anything from the outer primary if it were added, or if the secondaries could be combined to increase the power out. =]
Mags
Good question , i made one with one coil inside (the Micro ) but was care less and did it the wrong way around , so its not wound in the right direction.I should have a second look at it  , and come back with more.
There is also more loading , if it is true that the jt coil are blind to the pickup coil load in most cases , but 2 pickup coil on the same axe that is another ball game , i connected them mobius like and got better results.
After writing this i have to comment that the micro is not the best design .
But i did connect all 3 pickup coil in series and parallel series got more light.
I am still at a learning stage and having so much fun , i hope you will too.
One constant emerge , fat wire on the pickup coil are a must , i used the biggest i had , and now looking for bigger.
I still have so much info , i will be busy this weekend making videos of most important coil i have and try to show what i mean.
Thanks Mag
Mk1
Quote from: skippula on March 12, 2010, 10:52:19 PM
Mk1
Thanks , i have some patience and share a name with a saint but it is all about determination .
You are welcome !
Mark
Mk1
@all
I made this in hope of explaining how to design you own coil.
To get efficient more efficiency you need at least 36 turns per jt wire .
The offset 10 degree is considering a second parallel layer so they each 5 degree spacing on the orbit side . I still not sure but i have reason to think that going bellow 3 degree is causing the load to be more apparent at the transistor.
jeanna
Mark,
In the drawing you show a perfect triangle. You begin by moving toward the tube and end away from the tube (I am referring to the red arrows.)
When the one triangle is finished you must move on to the next spot to begin the next triangle.
So, my question is...
If your start and finish point is 7 on a clock, is the next triangle going to be toward 6 o'clock or 8 o'clock?
Did you try both ways?
I do not understand what you are saying.
About the second layer, I am assuming the bifilar is made in alternate wires on the tube on each layer. Is that right?
Thank you,
jeanna
