Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
woodycad
It's lost time,
only turbine principle catch energy.
Study fluidity... in The Fundamental Universe project!
All the matter is fluid, so as entire Universe!
See much more than 100 pages published, for free, on the project site!
Not spend time...in vain!
Mk1
Quote from: woodycad on March 17, 2010, 03:44:54 PM
It's lost time,
Well i wish you would at least offer some English version of that 100 pages.
Because all i get from you are pictures. I think i would loose more time learning Romanian then spend time...in vain!
I wish you would at least permit to copy character in your document that way i could use a translator , otherwise i am wasting my time ...
Thank for the pictures.
Mark
Mk1
Quote from: jeanna on March 15, 2010, 08:43:24 PM
Mark,
Did you ever give us the amps draw on your coil?
thank you,
jeanna
Sorry i could not answer sooner , it draws about 160 mili , but it changes form one transistor to the other .
I got some working from 70 mili to 230 mili .
I however am not too concern about it , since i am pushing in the opposite direction for the rest of the crowd , i am a bit alone here ...
Most are working to get the lowest input , i am working on getting the most current out .
I already see sparks yellow one when connecting connecting the secondary to the bulb , i tried to get them on camera no success.
The 2 volts bulbs is as bright as can be and the 6 volts 250 mili , is getting brighter everyday.
Mark
Mk1
Quote from: wattsup on March 15, 2010, 11:23:25 PM
@MK1
Sorry to but in with this question about your AG coils.
If you have one that has more then one winding of the 45 degree coils, let's say if you had 2 or more 45 degree windings, then just pulse one of them and collect from the others either in parallel or in series. Then put those in series with the outer horizontal coil and see what kind of output you get.
It is possible that a pulse on one winding, will not only impart to the others but the others will then re-impart some back to the pulsed winding since all of them are inter-crossing. There must be a few frequencies to find that will agree with such a scheme.
I would be very interested in learning the result of this.
Added:
Again about the AG coil, I have a funny feeling the ultimate result will eventually be found to be with two of these coils like the Hendershot.
The make of the coil dose show us some but we need to see how it works .
I don't think it works like the hendershot a mean the honeycomb coil , because of the orientation of the coil .
The field of the coil i make will act like a regular wire air coil of about the same radius .
The hendershot has the crossing field on a different axe altogether , but i do see why he would put transformer inside a coil .
I started to make a second and third coil , i will go Russian doll .
The bigger one dodecahedron 10 steps 5 turns per rotation .
Then 8 steps 4 turns/rotation octahedron .
The last one 6 steps 3turns /rotation tetrahedron.
But thanks for the comment , Keep them coming.
Mark
