Self running coil?
Started by gotoluc, March 13, 2010, 12:40:57 AM
penno64
Hi Luc,
It may be that the switching device you are searching for is a solid state relay.
With this, you can totally isolate the two halves of your circuit.
Must admit though, I am like you, not all that strong in electronics.
Good LUCk
Penno
gyulasun
Quote from: gotoluc on March 13, 2010, 04:34:37 PM
Is the IRF840 also the same capacitance?  because I get the same effect with it also.
Yes, more or less it has similar capacitances in the 1-2V range too, maybe a bit higher than for the IRF640, see Figure 5, Page 4:
http://www.vekoy.com/UserFiles/File/PDF-liitteet/IRF840.pdf
Gyula
gotoluc
Quote from: Omnibus on March 13, 2010, 04:38:23 PM
Hi Luc,
May I ask you what kind of a scope are you using?
It's a 200MHz USB scope, DSO-5200
Comes also with a software spectrum analyzer
You can buy them on eBay.
Luc
void109
If you have the time, a circuit diagram would be very useful indeed.  I'm perplexed - in that I think I understand that when you disconnect the battery, you're leaving an open circuit in the drain/source path that's pulsing the core - if that's right (which it may not be), then what in the world would you still need to continue pulsing the gate for?
A circuit diagram would be brilliant  :)   Also - you probably have, or maybe not, but what affect does placing a pickup coil near the magnets have on the effect?  Its all very exciting!  I'd like to go patch up a replication but I'm unsure of the specifics of your circuit.
Thank you for your ingenuitive work, its inspiring.
gotoluc
Quote from: gyulasun on March 13, 2010, 04:45:46 PM
Gyula
Thanks Gyula
So even if I had an OPTO isolator this would happen also?
Luc
