Self running coil?
Started by gotoluc, March 13, 2010, 12:40:57 AM
NextGen67
Quote from: NextGen67 on March 19, 2010, 07:59:40 PM
HarryV,
You are right in a way.
If the core have a reaction, then the magnet has its counter reaction, I was not clear enough in my idea... What I tried to point out is that the effect we seem to have [the pick-up coils having no influence on the input energy] is caused by the core its domains [and not the magnet vibrating itself].
If you 'tight up' the magnet and the coil together, so that the motion of the magnet is very restricted, this would have a better outcome for the mentioned effect. I do not want to go to deep into this, because it might open a lot of side way argumentation, which would be not a good idea for the progress of Luc's work;)
However, I hope to make it clear what I mentioned before.
Note that this is based on Luc his pick-up coil position, in which he says that the position he found is the best place for optimal receiving of energy.
NextGen67
Quote from: HarryV on March 20, 2010, 06:04:09 PM
Well, I think luc's effect requires the motion of the magnets because the motion of the magnets induces a current in the coil. If I am right clamping the magnets will reduce the effect.
Otherwise I don't see how the rotation of the domains by themselves could lead to overunity.
The question is does the energy required for rotation equal or exceed the energy of the induced current due to the motion of the magnets. If it does, then it is not overunity.
Hmm, I'll keep it short. Would the motion of the magnet not require energy? I mean swapping it back and forth can't be done for nothing... So imagine you clamp the magnet to the coil, and effectively prohibit physical movement of the coil... Now there happens some kind of pressure, since the fields still try to push each other of. Now if the magnet is tight and can't move, what happens with the energy that normally moved it? The magnet won't give way.. and *what* is actually pushing this magnet *what* caused the field that seems to push against the magnet.
NextGen67
forest
magnetic field has INERTIA, because nothing can react faster then light
push magnet field ,disconnect power source but connect LC circuit alone (caps and coils), magnetic field respond generating energy excess in LC circuit
apparently because battery was removed then this circuit has potential to push magnetic field of magnet with synchronization with LC resonance.
Like a child on swing.If inductance is not rigid then energy is amplified.
forest
how this circuit is GROUNDED ? electrons may be moving from ground
gravityblock
How To Build Solid-State Electrical Over-Unity Devices, http://www.overunity.com/index.php?action=downloads;sa=downfile&id=380
The purpose of this paper is to present the "hidden" mechanism that is at work in these devices which causes them to produce excess electrical energy.
GB
HarryV
Quote from: gravityblock on March 20, 2010, 07:43:30 PM
GB
When I click the link I am asked to logged in when I am already logged in. whats up with that?
