Self running coil?
Started by gotoluc, March 13, 2010, 12:40:57 AM
e2matrix
Quote from: forest on March 20, 2010, 07:33:06 PM
how this circuit is GROUNDED ? electrons may be moving from ground
Normally it was not grounded but as I suggested this to Luc as a way that might increase current flow he did try it but said it made no difference.  I'm planning on trying it with a ground as I had read in a circuit over 20 KHz it might add to the current flow.  Easy enough to try an Earth ground.
gotoluc
Quote from: NextGen67 on March 20, 2010, 05:52:32 AM
@Luc,
Luc, just send you a PM, subject named: Tests...
Could you perform these for me when you got some time?
I forgot, what was voltage of your Caps? ( 2*3900uF at ? Volt. )
It might be better to include the cap value in the cleanup drawing of your circuit, as it *does* make a difference on your tuning frequency.
NextGen67
Hi NextGen67,
let me know what test you want done.
The capacitors are 3900uf - 400vdc
Luc
gotoluc
Hi everyone,
I had a little free time while my son is visiting his mother and made a new video.
However, it's not showing any over unity :(
Sorry :-[  this may not be what we were hoping for :-\
Let me know if I'm missing something.
Luc
Link to video: http://www.youtube.com/watch?v=c7CsBr7ouPE
gotoluc
Quote from: gyulasun on March 20, 2010, 09:18:34 AM
Hi Luc,
First, I am sorry again I suggested the CNY17 opto for this task, as I wrote in the meantime but it must have been late. I owe you a beer or two..  :)
While I agree with the idea of using a MOSFET or a swithing device with much better parameters than the IRF640 (and here is another suggestion to a MOSFET type, use them both in parallel to reduce RDS: http://www.vishay.com/docs/71434/si1026x.pdf )
Question still arises: how your circuit works?  if there is resonance at the output side of the FET with the toroidal coil, then a FET with much less output capacitance could be tuned to resonance? surely it could but perhaps at a much higher frequency that might demand more input power (in switching circuit the higher the speed the higher the power demand gets, though this is nearly a linear dependence.)
I have been pondering on the following: let's say 4 pick up coils (optimized) could be used around the present toroidal coil and their individial outputs are summed up either in series or parallel or both.  From this pickup power the CMOS 555 could be run.
Now by choosing a more preferred MOSFET type instead of the IRF640, the 1-2mW summed output from the pickup coils could already be enough juice for driving the gate source input, that would have less than 100pF input capacitance.  This is what I think.
rgds, Gyula
PS Luc, what is the type of the CMOS 555, please?  (LMC555  TLC555 ICM7555, else?)
Hi Gyula,
the new CMOS 555 I got is a TLC555CP.
It is what I used in the new test 10 video I just posted above.
Luc
gotoluc
Quote from: mscoffman on March 20, 2010, 01:49:37 PM
I detect energy levels are beginning to converge.  ;)
For an experiment I would be interested in seeing
the maximum overunity gain measured two ways.
One time with a stopwatch while the voltage goes
from say 16.64Vdc to 17.64Vdc. The other would
null out the voltage change with a variable resistor.
Then measure the resistor setting with the DVM.
These things wouldn't take very long in a video
The other thing would be to build the NE555 cmos
timer circuit powered from dc derived from the reasonant
independent pickup coil. Have the NE555 output frequency
driving a 2nf capacitor to ground to see if you can get
to the required 10.94Vac pp. drive signal level of the
IRF640. (caution here)
Finally, I think you should purchase two IRF510 mosfets. Install
them in parallel in your experimental breadboard (easy) just install
them next to one another with all S,G,D's  connected to each
other. Now you have a Fet with the following characteristics;
Rds = .20ohms (very similar to the IRF640) and  Ciss= 2 x 135
= 270pf (4 times lower then IRF640). Now see what that will do
by tuning and measuring. I expect gate drive might be reduced
down to 3.0Vac pp! Now measure maximum overunity. One needs
to keep fingers crossed, that lower input drive is not the cause
of caps charging. Make overunity measurements. Then take one
of the parallel IRF510's away and re-tune and measure overunity
gain again... You probably will be driving like ~100 times less power
into the circuit from the signal generator. It makes the gate driver
look like 30->40Kohms equiv.
I wanted to summarize what I have said in previous
posts.
a) Use a series variable resistor on the gate of the
mosfet in tuning for maximum overunity gain in place
of the signal generator's output level control in case
its not available. Signal generator <-> opto only logical
use of opto.
b) Use a variable resistor to null-out the voltage gain
on the bulk capacitors after setting circuit overunity
gain to maximum rate. (better use a fixed resistor in
series with the variable) Measure the variable resistor
setting with a DVM. Lower resistance means better
overunity gain.
c) Find an “outlier” mosfet with spec sheet Ciss<200pf
And Rds<1.0ohm The lower both of these values are,
better...Found one, See below. This will lower the
drive voltage by up to ten times from the 10.94Vac
pp of IRF640 and lower transferable power even more.
Unfortunately if net overunity gain gets damaged you
won't be able to tell whether it’s due to the lower gate
power injection or the higher Rds, so keep one's fingers
crossed that the overunity gains seen is really overunity
energy.
Here is a mosfet that looks very promising;
    IRF510;   Ciss =135pf,    Rds =0.4ohms  <= try this!
As long as these parameters are correct and it is a mosfet
function forget the other parameters as they tend to trade
off except max Vds. Before doing anything check against any
stupid errors.
You can find all sorts of Web "calculators" for various electronic
equations on google. Just type the formal description of
what you want into google search then add the "calculator"
keyword.
impedance of inductance at frequency calculator
reasonant frequency of inductor and capacitor calculator
:MarkSCoffman
Thanks Mark for the details in making a more efficient switch.
I will buy some IRF510 now
Luc
