Dakota Nuclear
Started by hartiberlin, April 06, 2005, 06:35:36 PM
hartiberlin
Read this,
it is very interesting !
It also tells you, what the FED is doing to you !
http://www.worldslaves.citymax.com/page/page/1769161.htm
kenbo0422
I've worked on nuclear subs.  The questions posed on this site http://www.worldslaves.citymax.com/page/page/1769161.htm about the subs shows his ignorance about them.  See my post about homemade nuclear reactors.  One of the criteria of learning to run a nuke power plant such as these was to know how they had to be built to work and the difference between a reactor setup and a bomb.  The reason I point this out about the above page is that it takes his credibility down a notch or two and makes you wonder about the other things he talks about.  Fluoride isn't good....  and swallowing the story of pretty teeth is absurd.  Chlorine is cheaper and eventually evaporates from the system with a good enough bacteria kill to give a standard coliform test a clean zero.  It even works in municipal wastewater systems which is thousands of times more polluted than the reservoirs.  Go figure....
Kenbo
Ken
Bruce A. Perreault
Kenbo,
Not many people know this but a reactor can be designed to produce high voltage direct electricity instead of heat. This eliminates the ineffficiency of the steam/turbine process that wastes energy.
                   -Bruce P.
Kysmett
Bruce,
Would this be that thing that you are keeping to yourself for now or do you have any links to references?
Bruce A. Perreault
Kysmett,
No, it is not the thing that I have been keeping to myself. It is an old Dec. 27, 1955 patent.
It is titled "Generation of Power" U.S. Patent No. 2,728,867 - http://www.tinyurl.com/4zkvm
I used this example in one of my lectures.
                  -Bruce P.
