Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Pleasant evening to ALL,
I have coated the opposite side with a thin coat of black iron oxide.(non conductive!!)  It looks funky in the picture because the rises appear higher than they are because of the lighting.  It actually turned out very, very well.  I was going to sand it, but no sense in that.  It is already very smooth.
Now, I am starting to wind my second Tesla Bifilar coil...
Cheers,
Bruce
Bruce_TPU
Good morning everyone,
Just a little test this morning, seeing how my first completed coil is perfectly dry.
The black iron oxide in resin, draws in the magnetic field lines very, very well, as intended.  And these are small magnets.  Everything is non conductive but the wire in the coil, of course.  I am very happy with this method of making a coil!   :)
Notice the one magnet is on the resin only side, but is till attracted greatly to the other side.
Cheers,
Bruce
Bruce_TPU
Howdy ALL,
My second Tesla bifilar pancake coil is now wound and ready for the fiberglass tomorrow evening...
Cheers,
Bruce
Bruce_TPU
Happy Sunday evening ALL,
I have finished the one side with my fiberglass and am soon to iron oxide the other side...  I have 8 of these to build, six more, so hang in there...LOL
Cheers,
Bruce
Bruce_TPU
Good Morning everyone,
Well, my second coil now has one side with iron oxide mixture.  This is interesting, because in my setup, there will not be a collapsing magnetic field on my ferrite, but rather a static.
The second picture is of my first two coils, stacked as I had drawn up, a few posts back.
Cheers,
Bruce
