Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
PYRODIN123321
Peace.
mscoffman
Here is an interesting experiment with a homopolar generator:
One interesting effect that would *prove* the difference between
homopolar current and dynamo current operation in a homopolar
generator would be the fact that the outside contact on the
rotating metal disk would always be minus DC polarity independent
of both the direction of rotation of the disk and the direction of
the magnetic pole flux in hompolar mode! While the electron's spiral
path would be in different directions, the electrons would always
spiral to the *outside* of the disk. This would be interesting
because this effect would defeat setting up a stack of opposite
polarity coils connected at the center and boosting the voltage
that way.
What one would like to do is to get rid of the high current, low
voltage brushes. I think that either a higher voltage DC or AC
or EMF signal could cross the magnetic field from edge to axle
Without being interfered with excessively by the generator's
homopolar’s DC voltage. That might be accomplished by an
energy-converter unit rotating with the rotor.
:S:MarkSCoffman
gravityblock
Quote from: mscoffman on May 24, 2010, 01:36:24 PM
that way.
:S:MarkSCoffman
I posted a design similar to what you're referring to,  http://www.overunity.com/index.php?topic=9271.0
Thanks,
GB
jtoastercamp
hi my name is Jeff and i have been running some field tests in my head on your design for the unipolar generator idea and i have found a flaw in your work!!!!!  i think   the pancake coil that Tesla developed is the incorrect shape!!!! to cause the proper magnetic distortion field inside the generator.   if you were to wrap the pancake coil in the manner of a walking meditation labyrinth i am almost certain that it would create the right magnetic field to harmonize everything and make the project work.  i have in all my studies i have not seen any attempt to change the design of the pancake coil,  i am new to this forum and my new computer i will attach pics of the exact sacred geometric details of the labyrinth this must be looked at.  i do not have the fabrication facility to make this project happen, all i have is the ability to design and field test my ideas on a mental platform.  i am willing to share all my ideas with anyone who will listen
david lambright
just wondering if anyone has seen TPUbruce around?...bruce, if you see this, check out the thread i started here at OU.... it is getting really interesting.... anyway matt is still waiting.....stay in touch......david
