Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Hi GB,
Nice setup!  What are you rotating it with?  Based on the info that Dutchy posted, it should certainly work!!  Now I am really stoked...!  I look forward to your results... I won't be home till Thurs, so can only watch.
@Dutchy,
Great find!  Thanks for posting that info!  I had seen a part of it before, but not the photo's, or actual build of any unit.  It would seem that someone else had a "part" of my idea... ;)
Now, I want to build a 12" unit, except, using N52 magnets, and replace his copper disc with "several" bifilar wound Tesla pancake coils, using stranded wire... That should put out some juice... hehehe
I like the idea of using some spacers, between the magnets in the array, I have to think about this...I think that I can come up with something...actually drilling a bunch of holes is not that bad of an idea...hmm.. need to think on that one.
I did notice that he did not use a plate on top of his magnets.  Would this be advantagious?  I think perhaps a thin plate would be.
Lastly, I think that the output can be multiplied, by stacking...ie.. magnet, coil, coil, coil, coil, magnet, coil, coil, coil, coil, magnet.  Three magnet arrays and 8 coils.
Cheers,
Bruce
gravityblock
I think the test was successful, http://www.youtube.com/watch?v=dgIlORURSbI
When I reverse the probes, the sign on the voltmeter changes.  Reversing the probes is to show that the voltmeter isn't measuring any stray EM from the motor itself, but is actually measuring the EMF between the axis and outer edge of the conductor.  The voltmeter is showing mV with one decimal digit.  The readings are fluctuating probably due to a poor conductor and movement of the probes (I used roof flashing for the conducting material. They had a roll of copper, but it was like $80) The readings are much higher than I expected, so I need to do more testing with the metal discs on an axle, and as far away from the motor itself in order to fully rule out any interactions between the coils, motor magnets, and the HPG.  I will also put a resistor across the terminals of my voltmeter.
I will continue to do more testing on this throughout the week to rule out any external influences.  Thick metal plates are not needed IMO, if the magnets are properly spaced.  I do think having the magnets attached to a thin metal plate, with the proper spacing of the magnets will make the field more uniform with better results.
[Edit:]  @Bruce, this publication may also make you fell better.  The experiment in the publication is different from what we're trying to do, but there are some similarities. http://www.distinti.com/docs/pdx/paradox2.pdf
GB
Bruce_TPU
Very nice GB!  I am pretty sure that your reading is from the mags.  slap some paper and add another lid and stack em up.
What are you using for a motor, a computer fan?
Cheers,
Bruce
gravityblock
Quote from: Bruce_TPU on April 05, 2010, 07:16:43 PM
Cheers,
Bruce
I'm using a computer fan for the motor.  I can't stack anymore discs, because I don't have enough magnets to make another layer, lol.  I have a lot of magnets sandwiched between those plates.
I now have plans to build a much bigger HPG with an axle and magnets attached to metal plates to act as a large diameter magnet, using either my dremil drill or my router for the drive motor (very high RPM's).  My dremil drill is adjustable in increments of 1,000 anywhere between 5,000 - 35,000 RPM's, so this would allow me to take measurements over a large range.  I think a DC motor would be better, but I will use what I have around the house for the time being in order to achieve really high RPM's.  With a little time and effort, I can now test some of my designs.  I'll be working on a good and flexible test rig to take measurements of various designs, including the pancake coil.
I really appreciate you sharing this idea on how to simulate a large diameter magnet using numerous magnets attached to a metal plate.  Thanks.
GB
Bruce_TPU
Hi GB,
I just finished reading through that .pdf that you posted.  Good stuff!  Interesting, in that it too proves, that the magnet rotating, NOT on it's axis can indeed produce power.  This tells me that the idea that the flux does not rotate, but only the magnet, is indeed a false assumption...for if that were true, a magnet on the outer edge of a rotor would consitantly "move" away from where it's flux had been and no power would be generated.
This indeed means that simulating a large magnet will indeed work!  The reason that their experiment with two NORTH facing magnets did not work is because of the way their machine was wired, it would be the same as sandwiching a disc/coil between north up and north down magnets.
I have written to steorn, about their zeroF bearings.  I will use two of them for this large project.  It will still be costly, making 12" diameter "simulated" N52 magnets, but so be it... The main items that will influence the power output that are obviouse is the strength of the flux field, and the speed of the rotation.  The items not so obviouse are, bifilar tesla pancake coils, or regular coils, or discs.  Stacked, not stacked, resistance of coil, etc.
Things I still wonder, if I want to drive it like a homopolor generator?  Can a "simulated" magnet work like a homopolor generator and generate spin??
You may try that with your magnet sandwich, GB!  Add a nail to the bottom and see if you can spin it like a single magnet/nail homopolor generator...inquiring minds want to know...
We need to source a very strong epoxy, and I am thinking of using a 12 Round of stiff styrofoam for spacers.... I want to build strong but very light!
I have already designed a simple double brush system to take off power.  I will try simple, unless simple doesn't work!...LOL
Cheers,
Bruce
