Schottky Diode Help
Started by rukiddingme, March 22, 2010, 04:35:15 PM
rukiddingme
Cool, so the either the RK44 or the bat 46 would be appropriate for a system running at 9 volts and .8 amp.
Is there any advantage from using bundles of diodes of will just one diode be better?
If this is correct, thanks all.  :-)
kooler
hy
the rk44 has big leads on them so they won't fit in a solderless board 3amp diode..
(breadboard)
just thought i tell you before you bought them..
robbie
rukiddingme
Quote from: kooler on March 24, 2010, 01:05:21 AM
hy
(breadboard)
robbie
No worries, I'm going to bundle them and make a full wave bridge, so it'll be a permanent thing. tks
jadaro2600
Having several low voltage drop diodes will boost your forward current capabilities, but if one of them fails the reverse voltage, then all of them becomes useless to suppress the one which failed.
Such a low drop of voltage is usually indicative of a low reverse voltage as well, just a reminder.
rukiddingme
Quote from: jadaro2600 on March 24, 2010, 11:02:37 PM
I'll check them all before I install them.
What would cause a diode to fail in a full wave bridge?
