GBluer(Slayer) Exiter
Started by slayer007, March 28, 2010, 09:26:54 PM
woopy
Hi Xee2
Yes i can light the neon until about 10 centimeter from the coil, and about 40cm  with a led and AV diodes and 6 " antenna.
@all
Now some results with 7.5 volts  and plasma arc. I tried to put a coal electrode (from paper pencil), it works with different lenght. And i could get a burning arc (pix 2) during a long time without blowing the transistor. See the trace on the wood on pix 3.
What seems to happen is that there is first a plasma arc which slowly burn the wood than the charcoal of this burning transform the plasma in a welding arc and as far as it goes it burns the wood further under the coal electrode. During this process the current bounce up and down from 40 to 200 ma  . But it is difficult to say as the current is not stable.
Very interesting stuff
What do you think ?
Laurent
xee2
@ woopy
I used this mod of k1zm design with a toroid to get more power without burning out transistor. I am not sure if it will work with your coil but you could try it. The variable resistor is needed to keep transistor from over heating - do not go below 30K. Increase resistance until transistor is no longer getting hot.
slayer007
This video shows the effect an Earth Ground has when attached to the L1 coil.
http://www.youtube.com/watch?v=8JclIu6Q4OU
Rapadura
Quote from: slayer007 on March 31, 2010, 03:19:31 PM
WTF??? The LEDs light up when touch the floor???
What is this? Tesla's laboratory glowing in the dark?? Amazing!
slayer007
Thanks Rapadura.
@ Woopy I try to run my Exiter at 6v to 9V or lower.
But if you want to run it at 12v and the transistors get hot you could just make a bigger L2 coil.
20 to 30 turns should work good for 12v without over heating.
@ All the capacitors in the circuit I posted above are not needed for the light to work.
I was just trying to show a couple places were you can collect power to charge another battery while running the lights.
