GBluer(Slayer) Exiter
Started by slayer007, March 28, 2010, 09:26:54 PM
slayer007
Quote from: xee2 on April 05, 2010, 02:03:08 AM
@ slayer007
Is this your A? This is a dipole antenna. But, a very high field voltage would be required to get the needed 0.7 volts across the diodes to allow current to flow through them. I could see this happening with your exciter generating a field, but I would not think the ambient field would have a high enough voltage when the exciter is off.
Yes that is the basic circuit.
It will work by it's self with the Exiter disconnected.Last night I disconnected the Exiter and let it run all night I want to see how far it will charge the capacitor.And see if it will quite running after the capacitor reaches the voltage across the rectifier.(Thats around 1.3v)
xee2
@ slayer007
It would seem that you have made a big crystal set radio. This is another version you might want to try. Also, germanium diodes might work better than silicon since they have lower junction voltage.
xee2
@ slayer007
In a loop antenna, the coils should be parallel (rather than as in my drawing) and spaced far apart for best gain.
synchro1
The RF radiation emanates from the Cosmos. Cosmic RF radiation generated by distant galaxies in outer space.
conradelektro
@ slayer007
Hello Slayer, I watched your YouTube channel and try to understand your Exiter circuit. Great stuff!
Please excuse the silly questions, it is propably obvious, but I can not figure it out by myself.
Would your Exiter circuit work when I dispense with the diodes (4 x D1, 2 x D2) and the two capacitors, as indicated in the attached drawing?
I gather that the intention is to charge the two capacitors (or batteries) while doing all the other things with your big coil (like the transmission of energy to various tubes and LEDs)?
I want to build a very simple initial version of your circuit (without the diodes and the capacitors), if this is possible?
I guess it is essential to use the two transistors (2N2222 and MPSA06) as indicated in your schematics?
You explained the winding of the coils (L1 = big coil and L2 = pancake coil) quite nicely, I think I got that.
Do the additional towers just sit there, or are they connected to something? I see a length of wire coming out on the top?
I see also a length of wire coming out on top of L1, is this essential?
Sorry, a lot of questions from an inexperienced want to be experimenter.
Greetings, Conrad
