GBluer(Slayer) Exiter
Started by slayer007, March 28, 2010, 09:26:54 PM
slayer007
Here is the latest circuit I have been using and video.
After five days of running and switching the batteries around.The voltage in the batteries was still close to the starting voltage.
The voltage in the 6v battery was 6.25 from 6.13.
The 6v battery was a little to much but a AA battery charges very good.
The output from the L1 coil is also a little brighter with lower voltage across the capacitor.
http://www.youtube.com/watch?v=hzWdiO_aN2Y
stprue
Sweet vid slayer!  Looks like a promising set-up you have.
stprue
Quote from: Groundloop on October 20, 2010, 05:44:30 PM
@stprue,
Thank you for the clarification. So the base needs only a little feedback
from the field of the trigger transformer to run. So if I put a very high
value resistor from base to the plus rail then the oscillation will start
every time by itself as long as there is a pick up antenna on the base.
Thanks,
Groundloop.
Give it a try with the resister GL!!!  I haven't you may get some great results.  I never thought to use a resister because you can control the draw by moving the base metal away or closer to the output metal.
Lets see what happens
;D
Groundloop
@stprue,
I did my first try to make a circuit with a xenon transformer today, but failed.
I did blow up the transistor due to a soldering error. :-) Will try again tomorrow.
Groundloop.
nievesoliveras
@groundloop
The pickup wire on your schematic. Is it winded round the trigger transformer?
Jesus
