free energy circuit setup
Started by FreeEnergy, April 01, 2006, 02:35:41 PM
NerzhDishual
Hi Elvis!
You asked "... What is a DC-DC converter?"
I have purchased a small one (24.90 Euros) - Picture joined.
The specs are:
Input voltage 12 - 13.8 Vdc
Ouput voltages 15 - 16 - 18 - 19 - 20 - 22 - 24 Vdc
current 6A max (for 15 - 16 - 18 - 19 - 20 Vdc).
/ 5A max for 22 - 24Vdc output)
It is used to power a portable computer with a car battery.
I have received my 100 000uf/40V cap.
I will try to run my motor with it.
If it runs enough time I will purchase another cap else I will also get another motor :)).
BTW: thanks a lot to FreeEnergy for the link.
Best
Nolite mittere margaritas ante porcos.
NerzhDishual
Hi guys
My results : it does *not* work.
I utilized:
A 12.5 V battery.
Two 0,1 farad capacitors C1 and C2.
One small toy motor.
One small mechanical meter, two pulleys, a rubber band
(which act as a load)  to count up the motor turns.
Charge C1 whith the bat. (I got about 12.9 volts)
Run the motor with C1 (the "main cap").
Count the turns (ntotal) . I got about 1000 turns.
Charge again C1 with the bat. (I got about 12.9 volts)
Run the motor by discharging C1 to into C2 through the motor.
Count the motor turns (nthrough) . I got about 500 turns.
Run The motor with C1. (at about 12.9/2 volts)
Count the turns (nC1) . I got about 250 turns.
Run The motor with C2.  (at about 12.9/2 volts)
I got no noticiable gain...
nC1+nC2+nthrough =/= ntotal.
These are average numbers.
I made 5 experiments with C1 as "main cap".
I also made 5 more experiments after having swapped C1 and C2. (C2 as "main cap").
To be more accurate I got: (nC1+nC2+nthrough/ntotal) = 1.04. (4% gain).
This is not enough to make a favourable conclusion.
BTW:
Elvis was right: without load I grossly got about 50% gain, but this proved nothing.
Pictures to come soon.
Best
FreeEnergy
thanks NerzhDishual for the confirmation. at least now we know, unless you did something wrong.
NerzhDishual
Thanks FreeEnergy (my namesake :))) for answering.
These were not my last words.
I will try with another stronger - but not so greedy - motor
(and another load = a weight lifting) and - if needed - order more caps.
Actually, I keep on ordering stuff and spending money for Free NRG... :))
I will also try a JL Naudin "proposal" experiment with a
"bifilar-coil-between-two-caps"(http://jnaudin.free.fr/html/tepcoil.htm)
I do like winding bifilar coils. :))
Best
Nertz_Dishual
It is from Breton language which is not a latin one like French.
Nertz (=/=nerves =/= energy)
Dis (=/= non)
hual (=/= hug)
=/=  energy non hugged = Free Energy.
NerzhDishual
Pictures?
How can you insert an image in this post?
