Thanks to ALL for your help!!
free energy circuit setup
Started by FreeEnergy, April 01, 2006, 02:35:41 PM
FreeEnergy
valveman
PG46
One reason why you may have higher voltage in on cap than another is that the capacitor does not discharge fully so back emf adds to the partially charged cap.  Unfortunately this system will die out as a load draws current.
Valveman
pg46
Valveman-
Thanks for your opinion. Perhaps you're right I'm not sure what is happening there. I heard of back EMF but don't know anything about it.
The two things that I found are -
1) 2 motors will run longer than 1
If I use 2 caps and one motor as in experiment #1. I can run the motor(M1) for 14 sec when discharging C1 into C2
In the sixthflyingman setup the 2 motors M1 and M2 will together run for 17 sec when discharging C1 into C2, a 20% increase
2)increase in total voltage when discharging into other caps-
When charging the cap(s) using 14 to 15 VCD and then discharging into other cap(s) I find at least a 4% increase in voltage in total across all of the caps. So for example if I charge C1 with 14V and then discharge into C2 I could end up with a figure of 7.3V in each cap
best regards,
valveman
Back EMF.  EMF (Electro Motive Force)  Back EMF occurs because a motor has windings which essentially is a coil.  A coil is nothing more than an inductor and an inductor opposes the flow of current ie current lags the voltage by 90 degrees.  In a dc motor, you have a commutator that switches on and off the motor windings and creates a magnetic field.  The coil builds up a magnetic field when the commutator connects the coil.  When the connection is broken, the field collapses such that the current flow when collapsing, flows in the opposite direction that created it.  This reverse flow works in opposition to the current you apply to make the motor turn.  This back emf is not a desireable thing and limits a motors RPM and efficiency.
Valveman
pg46
Thanks Valveman-
So EMF messes with the efficiency of motors, huh? Thanks for the info. Will have to give all your info some time to sink in. Thanks!
I find that charging and discharging the caps direct into each other without the use of motors gives me similar results, that is an increase in total voltage. So if for example I charge C1 to 14v and then connect direct to an empty C2, then I might have 7.5V in C1 and 7.5 in C2 also. I would have expected 14V total or actually a bit less even to account for some kind of efficiency loss. I can carry on down the line with charging a 3rd Cap, C3 direct from C1 and C2 which are now connected and wind up with 5v in each cell. I have carried on like this up to 8 equivelant caps in a row all hooked in parallel. So I might wind up with 2volts each in eight caps at the end. Which is 2 volts more than the 14 Volts I began with, 2x8=16V...hmm...??
Kinda cool that you can get power from motors all the way down the line while doing this little trick too. So anyone know how to gather up these little 2 volt charges that remain in the caps and combine them back to a more useful 12V to recharge C1 again?
