CLaNZeR can achieve overunity!
Started by Rapadura, April 13, 2010, 11:35:36 PM
tak22
K&J have cubes for making Halbach Arrays
http://www.kjmagnetics.com/proddetail.asp?prod=B888%2D2PE%2DN52
http://www.kjmagnetics.com/proddetail.asp?prod=B888%2D2PA%2DN52
QuoteDimensions: 1/2" x 1/2" x 1/2" (- 0.127" hole)
Hole perpendicular to magnetization direction
Material: NdFeB, Grade N52
Magnetization Direction: Thru Thickness
Weight: 0.482 oz. (13.67 g)
Pull Force, Case 1: 21.48 lbs
Pull Force, Case 2: 24.24 lbs
Surface Field: 6451 Gauss
Max Operating Temp: 176ºF (80ºC)
Brmax: 14,800 Gauss
BHmax: 52 MGOe
These 1/2" cubes are designed to be used with our B888-2PA-N52 cubes to create Halbach Arrays. The holes are sized to allow a 1/8" rod to pass through, which will hold the magnets in alignment in two dimensons, allowing easier assembly. Threaded rod can be used, which will allow nuts on each end to provide the clamping force needed, or plain rod can be used with any other clamping force.
We are working on a detailed page all about Halbach arrays, but in the meantime, a lot of good information is available from Wikipedia: http://en.wikipedia.org/wiki/Halbach_array.
infringer
Rapudura technically speaking it would be overunity if you measure the amount of energy to put into getting it past the sticky spot then measure the output once you achive COE > 1 it is overunity I don't care how you slice it!
We all know overunity is possible or we would not be on this forum today.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
FatChance!!!
Quote from: infringer on July 20, 2010, 10:30:30 PM
You ought to rephrase that sentence:
We all hope overunity is possible or we would not be on this forum today.
sm0ky2
Quote from: FatChance!!! on July 21, 2010, 05:57:55 AM
hmm....
some of us know that overunity is possible.
some of us hope that overunity is possible.
some of us are convinced overunity it is impossible.
I think that all of us are at different points along the path of enlightenment.
ClaNZer has achieveD overunity, more than once. and he can/will do it again, the next time a quilified device presents itself before him for testing. He's much better at it than most of the rest of us.
Airstriker
Quote from: sm0ky2 on July 22, 2010, 02:51:13 AM
I've not really seen any overunity achieved by ClaNZer. If you have, please enlight me.
