GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
DeepCut
OK i put a cap on and the voltage counts down from 25 to 0.6 and statys at 0.6.
What am i doing this for and what does it mean LOL ?
p.s. it is the 47uf/35v cap.
Gary.
DeepCut
OK my fault (as usual !) one of the coil ends wasn't contacting the rectifier properly.
I have rectified the situation (LOL !).
OK.
I have made some adjustments to the system so here is an appraisal of current setup :
1. A DC PSU is powering a Bedini circuit.
2. The Bedini circuit is driving a magnet and the drive coil is now air-cored.
3. The magnet is rotating inside an output coil.
4. The output coil goes through a full-wave bridge rectifier with a 47uF/35V puffer cap.
The coil resistance is 90 ohms.
Results :
INPUT : 9.53 VDC  @  0.070 A = 0.6678 W
OUTPUT : 36.8 VDC
The current is :
I=V/R = 36.8/90 = 0.408
So the output watts is 36.8 * 0.408 = 15.0144.
Apparent COP = 15.0144/0.6678 = 22.48 !
Some of you guys MUST have the time to explore this in parallel with Tom and i, it's just far too interesting not to, surely !
I am buying a DPDT switch or relay tomorrow, this thing has to self-run.
Also, Gyulasun, there is no change in voltage/current at the PSU when the cap is on.
Thanks,
Gary.
FatChance!!!
Wow, if you surely got COP 22 then a self runner is a must.
And hopefully a small video for us to see.
Otherwise you need to check where the measurement error lies.
Hopefully there is no error this time.
How are you gonna adapt the high output of 36V down to 9V input?
The best way is using a regular buck switch with an efficiency of 95%.
But maybe switched electronics is out of your league?
Then a standard linear regulator, type LM7810, for 10V output could
work fine due to the low input currents of 70mA involved.
http://www.fairchildsemi.com/pf/LM/LM7810.html
DeepCut
Thanks Fatchance.
Yes i'm a noob with electronics but i can construct simple circuits from schematics.
I'm off to the shop today so will look for the right sort of switch.
I double-checked the figures and i'm sure it's all correct. It's hardly complicated so there's little room for error even for someone like me who rushes sometimes.
Will report back later.
Thanks,
Gary.
Bruce_TPU
Tom, who originated the idea also has overunity.  He and I write one another often.  He is soon to be working with much larger magnets.  I can not for the life of me figure out why more people are not interested in this.  Tom has given all of the details and Gary has sought to replicate.
Gary,
What size wire are you using for your pick up coil?  How many feet?
Good work.  Now post some videos and pictures for the forum, please.
Cheers,
Bruce
