GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
DeepCut
I'm thinking i should rectify both output coils seperately then sum the output after the bridge ?
*EDIT* then again, after separate rectification how on earth can they be summed ?
Surely it's like having two power sources trying to go to one input ??
Anyway it's 4am here so im of to get some shuteye, nn :) *EDIT*
Gary, the ever-confused (and sleepy) ;+}
Bruce_TPU
Quote from: DeepCut on May 07, 2010, 11:03:55 PM
I think you have induction from your motor coil into your output coil.  Seperate the coil at that one spot, so there is no wire between the motor coil and the magnet at this one point.  See attached pic.  That should work....
Cheers,
Bruce
DeepCut
Hi Bruce.
I have widened the gap between the drive and pickup coils and it still cuts out when a circuit is formed by the output coils :
http://qvision.pwp.blueyonder.co.uk/coilspace.jpg
Here is a vid of it shorting :
http://www.youtube.com/watch?v=sp5CwUdmHCk
Am i wrong in thinking that you can't have two power sources (both output coils) fully connected ? Isn't that then a closed loop of power running around so it's one big short-circuit ?
The drive coil/circuitry is totally seperate from the pickup coils, not connected at all.
Gary.
gyulasun
Hi Gary.
Yes the two output coils mutually short each other if connected directly.  If you wish to use them together you can connect the two in series, this adds the output voltages  (you have to watch for this connection not to counter connect them because then their voltage difference comes out, not their sum).  IF you want higher current than you have to use thicker wire, just like the practice shows for normal mains transformers.
QuoteLast night, with the 100 ohm resistor, the motor wouldn't even start.
QuoteI tried starting the motor at 18 V then attaching the resistor but the motor just slows to a stop pretty quickly.
These are bad news unfortunately. It can only be explained by the normal Lenz law effect any normal generator has. You may say this is not a normal generator...  this is true BUT Lenz law is still valid, unfortunately.
QuoteAlso, my new multimeter was fine, but now i can't even read the voltage off a 1.5V battery !
Every reading i try to take the meter signifies 'off the scale' by showing a '1' on the left-side of the display !!
IT is a good idea to take the meter away from the revolving magnet field (or stop the motor) and just check it with a 1.5V battery again. If you find the same problem with the meter than it may be faulty? Check it in every possible range like resistor measurement, AC mains voltage in its highest AC range etc, be careful!
Thanks for your PM, just read it and sorry I do not have Skype or msn etc.
Will answer your problems here from time to time for sure.
rgds,  Gyula
DeepCut
Thanks Gyula, i thought as much.
What are your thoughts on this meter i am thinking of getting next week :
http://www.uni-trend.com/manual2/UT50ABC%20Eng%20Manual.pdf
Gary.
