Thanks to ALL for your help!!
MILLIONS OF COFFINS, WHO ARE THEY FOR???
Started by FatBird, April 22, 2010, 12:27:22 PM
Bruce_TPU
Fatbird,
You have posted your B.S. in a forum thread under, "What is Over Unity and Free Energy".  Now, unless you expect to make pictures of plastic containers, rotate, or pulse, to produce OU, please remove and place under forum thread, "self promoting losers promoting BS conspiracy theories" thread, or something similar.
You are welcome to your own thoughts, but do not ruin our forum by posting them wherever you want.
Thank you and you have a good night,
Bruce
Paul-R
They are water tanks. Most of us have one in the roof.
FreeEnergy
lol this does not look like coffins to me. but i guess they can be used for coffins i suppose.
anyway why would you post this under What is Over Unity and Free Energy? or was this an honest mistake?
FatBird
It was an honest mistake.
I apologize for it.
